Old 11-10-2009, 03:43 PM   #1
Default picco evo3?
i just purchased a picco evo3 and was going to install a jp1 pipe on but noticed that where the header goes in to the back of the engines its really loose. can soemone help me please
thanks
j
JHN1 is offline   Reply With Quote
Old 11-10-2009, 03:48 PM   #2
Maximo's Avatar
Unfortunately the EVO 3 comes with a Picco style exhaust coupler, it works great for Picco headers, but not so well for standard headers..... Here is the coupler your going to need to use
http://www.amainhobbies.com/product_...Ofna-Novarossi
Maximo is offline   Reply With Quote
Old 11-10-2009, 04:00 PM   #3
Velocity8T's Avatar
I bought this same engine & use the JP-3 pipe with it. When I first put the header on I thought the same as you...seemed kinda loose & gonna cause an issue. I put the same seal on the motor that is also in between the manifold & pipe (there are thicker & thinner ones). When I did this i also used a high quality water proof grease (Silkolene) on the seal. What I can say is I have run this combo all season without so much as a hicup from the motor or pipe. It will sit there and idle all day & at any point I pull the throttle it just plain goes!
Velocity8T is offline   Reply With Quote
Old 11-10-2009, 06:10 PM   #4
8&stuff's Avatar
Trader Rating: 55 (100%+)
hpi make a fat purple gasket that works nice on piccos. the evo3 is great on jp3. jp1&2 wasnt too impressed
8&stuff is offline   Reply With Quote
Old 11-10-2009, 06:15 PM   #5
mblgjr's Avatar
Trader Rating: 86 (100%+)
You'll def. want the JP3...
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-10-2009, 06:22 PM   #6
Trader Rating: 519 (100%+)
use the same-- http://www.amainhobbies.com/product_...Ofna-Novarossi
but I run mine with an 086 ofna/dynamite 086, and its really good....plenty down low with more top....
flame56mx is offline   Reply With Quote
Old 11-10-2009, 06:41 PM   #7
counterman's Avatar
Hey switch, what did you think of the jp header with that 086?
HPI/Hot Bodies, Team Orion, VP fuels, Pro-line, OS Engines, Futaba, Full Throttle R/C Raceway www.ftrcr.com
counterman is offline   Reply With Quote
Old 11-10-2009, 06:55 PM   #8
It was good, until the bearing incident--Switch?
Old 11-10-2009, 06:58 PM   #9
Integra's Avatar
X2..these coupler's will Easily go a season or 2.
Old 11-10-2009, 07:06 PM   #10
counterman's Avatar
Back when I ran picco's that's the only one to use. Make sure when you install it to cut it to size. Usually 2-3 mm narrower will be fine. The seal should be flush with the exhaust flange.
Pipe for mu Picco Evo3 .21 Gearhead racer Nitro Off-Road 15 05-27-2009 03:58 PM
Picco Evo3 or GRP .21???? aiyoaiya Malaysian R/C Racers 60 03-09-2009 04:57 AM
.21 Picco Evo3, G1 XP Pro, Novarossi 21-5 & O.S. RZ21 new/used on/offroad & pipes Wanabrc R/C Items: For Sale/Trade 150 02-10-2009 11:04 PM
Difference btwn 21 Picco Evo3 P9R and P7R onroad? dameetz Onroad Nitro Engine Zone 7 12-22-2008 11:20 AM
