Jammin X2 CRT body question
#16
This is interesting... Ben are they any issue with the pipe or cooling head rubbing against the bulldog body on the the x2 i mean the bulldog looks pretty narrow for the x2? thanks..
#17
It probly will lay on the pipe. Every other body that
Proline has made to fit on the CRT's lay on the pipe
and melt, so I wouldn't expect them to change there
ways now. Proline has always made the worst fitting
bodies for the Jammin truggys. I'm going to wait and
see what JConcepts comes up with.
#18
#19
Looks good Ben, thanks for posting
#20
The headlight design for the stickers on that bulldog body looks exactly like a rip-off of the Jconcepts style. I liked the old pro-line headlights better.
#21
diozxlive...The body is actually wider than the truck, like theres about a quarter inch gap of room on either side of the body. right now with a jp2 pipe on mine, the body doesn't even come close to touching the pipe. The engine head sits right in the flat bed too so nothing touches.
#22
Hey ben, anyway i could trouble you to measure how far down you went with the rear holes for the body mount?? thanks
#23
matt, the top hole goes down 17mm, also the front shocks need to be angled in one hole on the tower otherwise the caps rub a bit.
#24
Took some brighter photos
#25
thank you very much ben, Looks great, im getting my body this week, and appreciate the tips,
#26
Thats another problem that I always had with the
Proline bodies. You have to change your shock set
-up to get the body to fit properly. You would figure,
a company that big would be able to do more r&d on
there products. There is no reason for them to throw
a half-arsed product out to the public.
#27
a half arsed product, this body is not even for the X2CRt were mounting a RC8t body on a Jammin X2CRT, so these problems are just being noticed by us, on a proper chassis, these problems wouldnt occur
#28
ben kudos for a great job. what wheel adapter are you using on that truck.... thanks...
#29
#30
One thing I noticed, after looking at those pics closer.. Looks like you should trim a bit off the back of the body next to the shock tower. Looks like it will but up against that shock tower when flexing and crack the body eventually.
