Old 11-08-2009, 04:39 PM   #1
pballer2777's Avatar
Trader Rating: 27 (100%+)
Default different carb on a v spec
i think that i may have a carb problem on my vspec. i've tried tuning it til the cows come home with now luck, the only needle i have not touch is the mid range. it sounds like it motor is chocking up and will only run if i stay wot. i don't want to spend the $ on another carb and it not b the problem. so will any other carb fit on this motor so i can see if it is a carb issue.or maybe someone can tell me the stock needle settings including the mid range needle. this way i can see if its way out.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 11-08-2009, 08:24 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
Novarossi carbs (and RB, JP etc.) will also fit.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-08-2009, 11:06 PM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
NEEDLE SETTINGS:
High Speed - (see pg 17 of manual) 3 turns OUT from fully closed
Metering Needle - (see pg 22 of manual) Head of screw is flush with
ball link body
Mixture Control Valve - (see pg 22 of manual) Head of screw is 1 full
turn IN from flush with carb body
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 11-10-2009, 11:48 AM   #4
has anyone used a nova carb on a vspec with good success? i had a nova card lying around and put it on the vspec and so far seems to run good. so what i want to know is can i contiue to use this carb or will it damage the motor. i don't see how it could damage it but i want to b sure.
Old 11-10-2009, 11:55 AM   #5
wingracer's Avatar
Only bad tuning or an airleak would cause it to damage the motor.
I have never used a Nova carb on an OS but I have used an OS carb on a Nova motor with great success.
Team Shepherd USA
Old 11-10-2009, 12:18 PM   #6
thats what i figured, just wanted to b sure
V-Spec Pro Mod or EBMod JX21??? HiVoltg12 Nitro Off-Road 25 10-14-2009 05:07 AM
DONT BUY A V-SPEC!!!! GMS_Racing Nitro Off-Road 193 06-13-2009 06:03 AM
This V-spec is driving me insane. Jonro Nitro Off-Road 95 03-30-2009 02:35 PM
OS V-Spec Issues and Questions t0adman Nitro Off-Road 19 08-17-2008 12:39 AM
Need HELP with V-Spec Mo-Bo0st Nitro Off-Road 9 07-12-2008 08:47 AM
