Old 11-08-2009, 01:14 AM   #1
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Default LSN issue
First off yes I do know this is in the "tunning bible" I'm just realy having a heck of time getting this LSN setting correct. It just dont have much on the low end of power as far as 1/4 throttle wants to bog down as if getting to much fuel. I guess what im realy looking for is just a quick guide to setting the LSN.
Thanks in advance to all that responds.
kodiakbear7070 is offline   Reply With Quote
Old 11-08-2009, 02:07 AM   #2
shanty140's Avatar
1 simple way that you can use to make sure you LSN is somewhere in the ball park is to pinch the fuel line 1 inch from the carb after coming in from a high speed pass. The motor should idle up then die somewhere in between 3-5 seconds. If it just dies and the motor doesn't rev up it's to lean. If the motor takes longer then 3-5 seconds to die but still idles up right before you are probably to rich. It's a simple way to make sure your LSN is in order.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
O.S. 21 VZB High Idle Issue??? everyjuangohome Nitro Off-Road 9 03-25-2009 12:17 PM
Issue with my Revo TRX 3.3 Engine TADitto Nitro Off-Road 11 01-02-2009 06:54 PM
Newb question about HSN/LSN/ISS on REVO 3.3 Willystylee Monster Trucks 6 06-26-2008 02:14 PM
Idle issue/lean condition ? K.Copeland Electric Off-Road 8 05-12-2007 07:20 AM
