Old 11-07-2009, 06:27 PM   #1
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Default Problem with glow plug
As i was running my engine and came in for a temp check I noticed fuel coming out from around the glow plug. Is this correct to assume I just had it extremley rich and the glow plug not tighten down all the way down. Cause I did retighten plug and lean the motor a lil bit and didnt notice any more issues.
kodiakbear7070 is offline   Reply With Quote
Old 11-07-2009, 06:59 PM   #2
chris c's Avatar
Trader Rating: 60 (100%+)
turbo or std? if std the crush washer could be bad and if turbo the taper might be wrong did you change plug makers?
If you can make it I can break it
chris c is offline   Reply With Quote
Old 11-07-2009, 07:03 PM   #3
no stayed with orig plug and it is turbo also it is a cold plug
Old 11-07-2009, 09:07 PM   #4
Most likely just a little loose.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 11-08-2009, 12:51 AM   #5
Trader Rating: 117 (99%+)
Send a message via Yahoo to penguineman
I saw that happen a couple times on Vspecs. usually just tghten the plug up & it went away. the only thing we could think of was it just wasn't got tight when installed after changing it or the plug loosed up a little due to the difference in the metals & the heat expansion & contraction. just kinda what we had found & we was using OS plugs.
penguineman is offline   Reply With Quote
Old 11-08-2009, 12:59 AM   #6
Thanks for the insight I realy fill and felt like this was the problem cause i did tighten up soon as i seen the problem and shortley after it cleared up with no problem
Problem with starting engine - Pull start Aceboy Electric Off-Road 17 05-02-2006 03:52 AM
Freaky glow plug problem Hesky Onroad Nitro Engine Zone 12 12-26-2005 04:10 PM
