How many use compreesed air,(air compressor) for cleaning. This is very important to my race program. I use a Porter Cable 20 gallon air compressor with a 175 psi, What are you using ?
I have a small 1.5 gal husky that is very portable and very easy on the power thats available. When other compressors wont turn on mine always does. The tank is small but it fills very fast. I have used it all year and still works great.
i use a compressor to clean mine off too. its a lifesaver. makes it way easier. i spray the car dowm with a weak mixture of water and purple power..let it sit a minute of so...then blow it off.
-kyosho inferno, carbon fiber: shock towers, servo tray, center diff brace, fuel splash guard, Ackerman plate, wing, top front plate. axial .28rr, ported, turbo plug, vantage carbon fiber pipe, titanium drive axles, 30% ODonnell or 33% Byrons, shaved ring gears
yellow seal bearings
-Odonnell Z01b, big bore shocks, losi .26, ported, 30% ODonnell fuel, dynamite pipe
Air compressors are the only way to go when cleaning RC's!
But what do you know? LOL Sup FUNKIN??????
I agree Air all the way.. I have a littel Campbell Haufeld 1. gallon that works really nice at track that don't have air.. Got it at wally mart for like $60 a few years back..
Go Hard, Go Fast, or GO HOME!!
Jammin X-1 CRT
Sirio .21 EVO IV STi Kanai
Futaba 3PKS w/ FASST 2.4ghz
I use a 40 cu. ft. nitrogen cylinder quiet, small, extremely portable and economical.You can easily squeeze 250 psi out of it if your hoses will hold it. use caution when using pressures this high cause if you don't know what your doing you can drunk filter paper special comet speaker winding neighbor.
WHAT
RC8T, IGT2
ninja jx .21 ,jpx .28 , jpx.21
futuba 3pk
byrons 25%
BBM racing (southern california chapter)
i can see the words coming out of your mouth but I cant make out what you are saying.
- BCE 8ight T 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- BCE 8ight 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- powerhousercperformance.com <<Engine Mod Magic<<
- coldfusion fuel - www.coldfusionrcproducts.com -
- carolinasrc.com -
