Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-06-2009, 03:41 PM   #16
xBRxSAIGON's Avatar
cough: In an 8 though
XXX-T CR GTB, XXX-NT SPD, LST2 28RR, 8IGHT 1.0 RB WS7
xBRxSAIGON is offline   Reply With Quote
Old 11-06-2009, 09:57 PM   #17
Post
Mark from powerhouse says he may hook me up... What do you racers think of his mods? I am thinking i want the N21R, or the P5XL. The +4 is a little pricy... Keep the thoughts coming though, i want the right engine!
I love things the have LED's, plug in or go beep.
(\__/)
('X.X') <--- Bye Bye Bunny
RC8daBOMB is offline   Reply With Quote
Old 11-06-2009, 09:59 PM   #18
Well, the nova +4 is a little pricy from powerhouse, but maybe if i get it stock.... =)
(\__/)
Old 11-06-2009, 10:33 PM   #19
what are you looking for as far as characteristics ?
I am into the Picco's more then the other engines..... not that any of the other engines aren't great or anything, I just really like the responsiveness and power the Picco's have.... IMO the engine to get would be a Jammin JPX/Picco P7 EVO 3 on a JP-4... They are powerful, reliable and last a long time as well they are priced very good.... If your after something with some serious snot then a modified version would be my choice....
Maximo is offline   Reply With Quote
Old 11-06-2009, 10:41 PM   #20
I want a smooth powerband, lots of low-mid power, bust still have high top speeds. (i know im asking for alot) =)
(\__/)
Old 11-06-2009, 10:42 PM   #21
[quote=xBRxSAIGON;6573277]RB WS7lll w/ 2032 pipe[/QUOTE (cough cough)In any thing but a losi eight.
BeefHead is offline   Reply With Quote
Old 11-07-2009, 01:59 AM   #22
htcurt's Avatar
Smile
would definatley recommend the novarossi P5 XL Turbo if possible, just recently brought one of these after selling my RB WS9, the difference in the smoothness of the lower - mid power band is awesome. doing much better times despite the less power, as im racing much more tidy. Highly recommended, BY FAR THE BEST ENGINE I HAVE OWNED SO FAR. easy to tune, easy to break in and best of all Novarossi quality. Great on fuel. And an absolute bargain. Hope this helps
htcurt is offline   Reply With Quote
Old 11-07-2009, 03:18 AM   #23
NRGman's Avatar
cant go wrong with a Novarossi!
Team Associated RC8B | GOOOOO Team Associated!
<-| Team Associated RC8B | Novarossi Toro Nero 21T | DX3R | Purple Rush|->
NRGman is offline   Reply With Quote
Old 11-07-2009, 03:52 PM   #24
Default Nova P5XL(T)
alright... i have come to a narrow decision between the standart or the turbo... I have never used a turbo so can anyone explain what the actual plug differences are??? thanks
(\__/)
Old 11-07-2009, 04:39 PM   #25
PowerHouse's Avatar
Trader Rating: 36 (100%+)
The only decision you have to make is which plug you feel you would like to run. The difference between plugs is the turbo uses tapered threads and uses the taper at the end of it to seat against the head insert which eliminates the need for a copper washer. The standard plugs use straight threads and a copper washer to create the seal.
As far as performance differences, I have tested this many many times and the fact is, if you compare the same plugs in the same engine, they will perform the same. Many will argue this point but the fact is that it is a coil that glows due to current resistance and depending on the thickness of the coil and the fuel's flash point, that will dictate when the mixture ignites. The engine doesn't know the difference between turbo and standard plugs if they are the same heat range and type ie: shortbody or longbody. Standard plugs are cheaper than turbo so if you are on a budget, that will be the way to go plus the P5XL is cheaper than the XLT. Not by much but $10 is $10 especially when there isn't any performance differences between the two.
I run run the C6 series plugs in my P5 and I switched chambers in between rounds with a fellow racer to show him that there wasn't a difference between the plugs. We switched inserts and without touching the needles on either, both engines ran the same temps, time and tune as they did with the other chamber.
I have done this with many different brands of engines all with the same result. Take it for what it is worth.
www.PowerHouseRCPerformance.com
716-208-7290
Novarossi/TKO Bearing Dealer
RC America/Xray Team Rep/Driver
Cold Fusion RC Products Team Rep/Driver
PowerHouse is offline   Reply With Quote
Old 11-07-2009, 04:43 PM   #26
8&stuff's Avatar
Trader Rating: 32 (100%+)
I run jpx(picco)21 w/086 double bend header in truggy and get about 10 minutes in truggy. also as metioned earlier the rb hobby 9(mine with turbo button for $20 ebay) is what i run in buggy i also use with a double bend short with 086 and get over 11 in buggy easily with great smooth power. both of these combos are under $300 and will last 8+ gallons easy if used properly if not more. only reason i said +4 earlier is cause of your spending limit. really tho there is absolutely no reason to over spend
8&stuff is offline   Reply With Quote
Old 11-07-2009, 09:23 PM   #27
wow... I am rally liking those two engines... I am a little afraid of getting ripped with the JPX, i dont know why, i think its becuase of that i have never seen anyone( except one guy for like 30 secs at the track as i was leaving) run it. Can you explain how the hobby runs? thanks
(\__/)
Old 11-08-2009, 12:12 AM   #28
Alan D.'s Avatar
I run at Thunder Alley too.
I've ran the Nova 5kt and it ran good out there.
If you have the money Ninja with an 086 pipe will be way more than enough power to clear the jumps out there.
B5 runs really good too.
Thank You Hot Bodies
Alan D. is offline   Reply With Quote
Old 11-08-2009, 08:15 AM   #29
Unhappy
yeah, the ninja with the 086 was my initial choice, but its up there, and ive heard its got a jumpy powerband... I doubt its true, but its probably already out of the question anyway
(\__/)
Old 11-08-2009, 08:43 AM   #30
xBRxSAIGON's Avatar
RB WS w/ JP Racing 2032 and a Novarossi header..
Tags
.21 , engine , good , rc8 , rc8b
Forum Jump
REEDY .21 Nitro Engine Kevin Boyle Nitro Off-Road 647 Yesterday 05:49 PM
Sirio S21 CL7B .21 Long Stroke marki Nitro Off-Road 380 11-16-2009 08:08 PM
What Engine is Best? .21 for Buggy Victory Side Nitro Off-Road 45 03-25-2009 05:44 PM
Best .21 engine MBR52 Nitro Off-Road 39 08-13-2008 03:54 PM
Team VTX-B1 buggy and VTX-ST1 truggy Australia pieter Australian Racing 45 02-18-2008 11:56 AM
New to 1/8th Nitro, which .21 engine/pipe should i get??? mikezap Rookie Zone 12 02-07-2007 02:51 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
