Old 11-05-2009, 04:34 AM   #1
w_kirk_jr's Avatar
Send a message via Yahoo to w_kirk_jr
Default novarossi N.21L
i just bought one of the first wondering what pipe people sugest and how they perform
WILLIAM KIRK JR-
WWW.DIXONSRCRACEWAY.COM | SIDEWINDER | TEAM EPIC | A-MAIN HOBBIES
WWW.MYHOBBYDEPOT.COM
push aginst me! It only will make me stronger and faster-
w_kirk_jr is offline   Reply With Quote
Old 11-05-2009, 06:04 AM   #2
tc5 man's Avatar
dynamite 86 pipe high speed it gives u good milage and higher speed which this engine needs thats the only pipe i have tried
Old 11-05-2009, 06:06 AM   #3
tc5 man's Avatar
take the restricker out of the carb also so u can get more top end u still will get good fuel milage depeding on your driving really
Old 11-05-2009, 06:13 AM   #4
w_kirk_jr's Avatar
i have a nova 9886 pipe and short header i think this is the pipe ment for the engine but can't conferm it im going to call jim at about 3 today i know he can comferm an ill post up his answer
WILLIAM KIRK JR-
Old 11-05-2009, 06:21 AM   #5
mblgjr's Avatar
Trader Rating: 86 (100%+)
41021/9901 or 9853 work perfectly. 9886 will really soften the bottom.
Don't pull the restrictor out, 8mm is the biggest the carb body can go anyway.
7 or 7.5 work very well for med. sized tracks; 7.5 works all around very nicely.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-05-2009, 06:42 AM   #6
w_kirk_jr's Avatar
the pipes i have are jp3 jp4 os 2060 and a 053 grp twistlock pipe and nova 9886 what would be best
WILLIAM KIRK JR-
Old 11-05-2009, 08:31 AM   #7
mblgjr's Avatar
The JP's are generally fuel hogs (JP3) can't speak for the 4.
I'd start with the 053; then if you want less bottom and more mid/top swap to the 9886. Then if you want something between the two, the GRP 2053 runs pretty similar to the 9886; but with a downward shift to the whole power curve and not as much top.
Old 11-05-2009, 08:34 AM   #8
houston's Avatar
Trader Rating: 91 (100%+)
N21l? Must be an econo 3 port?
9886/41021. Don't use the 41001 or41005 on the 9886. It does not work very well
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 11-05-2009, 08:47 AM   #9
mblgjr's Avatar
Pretty sure he's referring to the N21B-Limited
Old 11-05-2009, 08:48 AM   #10
mblgjr's Avatar
Old 11-05-2009, 09:15 AM   #11
w_kirk_jr's Avatar
not the N21b limited jus a N.21R limited
WILLIAM KIRK JR-
Old 11-05-2009, 09:29 AM   #12
rossoh10's Avatar
post a link to the engine so were all on the same page
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 11-05-2009, 09:53 AM   #13
w_kirk_jr's Avatar
im sory i cant find a link it is the brand new engine it is a N.21R LIMITED not the 2001 BF or 21 BF not that series of engine engie looks identical to a p5 but is a 3port
WILLIAM KIRK JR-
Old 11-05-2009, 11:14 AM   #14
houston's Avatar
Yes that is the 3 port econo. And yes , the same pipe recommendations as earlier
Some people will say otherwise but I am 100% positive and can back it up with on track testing and many happy customers . Basically the same engine as n21bf limited but different case and head
Old 11-05-2009, 04:51 PM   #15
easyryder's Avatar
Are you a pro?
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
