Old 11-04-2009, 09:52 PM   #1
xBRxSAIGON's Avatar
Default This time I need help!!
My engine is pinging pretty good now and i dont know why. It was runnin good, plenty of power then it ran out of gas, I filled the tank, started it up it idled good but as SOON as i gave it throttle it would die. Now its doing the same thing but with PiNgInG nowww. Its not too lean because I always run my engines a little on the fatt side... Any help would be great.. And yes its a 28RR and yes i have to keep runnin it. It was great until now
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Old 11-04-2009, 10:01 PM   #2
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Was the fuel system primed really good before refiring? No air bubbles in the fuel filter(s)?
OR.... Did you break/ crack a fuel tank? Pressure line in good shape?
Just some ideas....
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-04-2009, 10:08 PM   #3
xBRxSAIGON's Avatar
Yah its solid, no air leaks or anything I always make sure its well primed before starting. Maybe I put the wrong plug in or something idunno.....
Old 11-04-2009, 11:16 PM   #4
Is it possably a coincidence your rod went south at the same time you ran out of gas or maybe it only appeared out of gas & was flamed out by internal probs? Possably chunk of fuel filter stone broke off & is blocking in main or mid jets?
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 11-05-2009, 12:29 AM   #5
xBRxSAIGON's Avatar
Yah maybe i'll take it apart and see, Can the wrong glo plug really make it run like h_ll???
