Old 11-03-2009, 04:10 AM   #1
Default Help Cleaning Motor
Hey guys can you give me any tips on how to clean the gease and dirt off ny nitro motor?
Its filthy.... What should i do with it?
kypreo is offline   Reply With Quote
Old 11-03-2009, 04:34 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
brake cleaner, nitro wash, etc
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 11-03-2009, 11:05 AM   #3
merdith6's Avatar
Default Denatured Alcohol
I would take the air filter off, clutch bell and bearings, and the header too, and leave the glowplug in it, then put caps on the carb, and exhaust too, and put the denatured alcohol in a spray bottle, I get mine at Lowes, they even have spray bottles too, it way cheaper to use than nitro blast. Spray it on and brush it with a toothbrush immediatly because it evaporates, and repeat a couple of times, then take the caps off the holes and spray it in the carb hole and turn it over gently by hand letting it work it's way into the engine, and as you turn it, turn it upside down and it will flow out with all the residual oil and so on, then put it in a clean towel, and dry it off, and don't forget to oil it with about 10 drops of oil....Peace out...
merdith6 is offline   Reply With Quote
Old 11-03-2009, 03:00 PM   #4
what kind of oil do yall use?
Biscuit451 is offline   Reply With Quote
Old 11-03-2009, 03:15 PM   #5
jamiekerr14's Avatar
Tornado After Run Oil...
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 11-03-2009, 03:20 PM   #6
I run denatured alcohol thru a siphon sprayer on mine. Use a brush to get off the stubborn stuff. Seems to work pretty good.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 11-03-2009, 04:03 PM   #7
Madbrad's Avatar
Trader Rating: 29 (100%+)
I remove it , cover all openings and uses brake cleaner and a small brush.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 11-03-2009, 04:47 PM   #8
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default top secret
Triethylene glycol
RayA is offline   Reply With Quote
Old 11-03-2009, 05:00 PM   #9
straight simple green, soak , scrub brush , rinse with HOT water.
jmpn02 is offline   Reply With Quote
Old 11-03-2009, 05:31 PM   #10
Kalgard Racing's Avatar
Try some of our Kalgard Contact Cleaner. It dries very fast, usaully before you have time to reach down for an air hose. Since it dries fast, it doesn't have time to hurt and of the O-rings or bearings or the rubber carb boot.
Kalgard Racing is offline   Reply With Quote
Old 11-03-2009, 07:44 PM   #11
gixxerman's Avatar
+1!!!!!!!
gixxerman is offline   Reply With Quote
Old 11-03-2009, 07:53 PM   #12
8&stuff's Avatar
Trader Rating: 55 (100%+)
x2 only time i walk into wal mart is to get non clorinated brake cleaner
8&stuff is offline   Reply With Quote
Old 11-03-2009, 07:54 PM   #13
I just use WD-40, but I don't let my stuff get caked up and burnt on either.
Soak it down, light scrub w/ a toothbrush and blow off with compressed air.
Keeps em nice and clean.
McFly505 is offline   Reply With Quote
Old 11-04-2009, 06:18 AM   #14
scwrod's Avatar
+1 on the wd40 toothbrush then air.
I have some of the Kalgard products. I will have to try the contact cleaner. Every time I turn around I find a new use for the Kalgard Products
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 11-06-2009, 04:00 PM   #15
xBRxSAIGON's Avatar
simple green, air chuck...
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Silver Can Motor Tips/Tricks TAMIYAMANUK Electric On-Road 1741 04-11-2014 01:44 PM
MOTOR COMMS 16skyline Electric On-Road 75 05-05-2007 07:02 PM
DC Motor Sports Discussion Thread: Curtis Schlaht Team and Company Discussions 2010 11-28-2006 10:42 PM
Cleaning our cars dct147 Nitro On-Road 152 12-14-2005 03:19 PM
Need help about Motor Maintenance and Lathe? Brushes? Solara Electric On-Road 17 08-11-2004 03:07 AM
