Old 11-02-2009, 07:39 PM   #1
Registered User
Default Why do my servos keep frying?
I just fried a JR 9100 servo on my throttle. This is the second servo in the past couple months granted the first one was poor quality. Anyway, I saw smoke coming from the servo seconds before it died. It got stuck at 3/4 throttle so i had the pleasure of chasing my car around the track before smashing it into a wall to finally get a hold of it. Now on my controller the throttle servo setting it set to "reverse" could this be a possible cause for burning this servo out? (the reverse setting on my controller allows for the servo to function is its normal manner) Also, i did not have to use the reverse setting until i bound my controller to another car. (this car has steering, throttle and aux all in the normal positions). Thanks for reading.
rememberthis is offline   Reply With Quote
Old 11-02-2009, 07:56 PM   #2
DezSlash's Avatar
What car is this in, what kind of radio you using, and have you adjusted your endpoints?
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 11-02-2009, 07:58 PM   #3
tc5 man's Avatar
could be to much brake epa or just a bad batch of servos like i had with hitec with centering the cheaper ones, do u use a lipo as a reciver battey
Old 11-02-2009, 08:10 PM   #4
I use the spektrum receiver and had a similar problem a couple years back. The problem was with the receiver. I had a JR9000T for steering, and it fried. I replaced it with a brand new 9000T and it also went poof in less than 1 tank. Frustrated, I replaced the receiver with another new one and the problem went away and I haven't replaced another servo since. If you have the opprotunity to change out the receiver, I'd try that as well. I had all my end points set, so it wasn't a end point issue. Even after I replaced the receiver, I didn't change the end points cause it was still good. Hope this helps. btw, the receiver I had last almost a year and a half in my LSP. To me, it was a decent life span for a large scale nitro vehicle that I used twice a week for almost the entire duration.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 11-02-2009, 08:14 PM   #5
Registered User
I am running a losi 8ight 2.0 with spektrum dx3s controller. I did make some adjustments to my endpoints, but I cannot confirm i adjusted them correctly as I am still fairly new to all this.
Old 11-02-2009, 08:26 PM   #6
fatdaddy's Avatar
losi servo death machine strikes again!
sorry to hear it man. Horizon has good customer service. i just sent a 9100 in recently and they replaced it 100% free. good luck
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 11-02-2009, 08:29 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
Check and make sure the throttle servo is not hitting the mud guard. I had to shave down the guard on my 2.0. I went through 6 servos when I first got the 2.0 until a losi team driver pointed it out to me. Check it out and I bet it's hitting the side mud guard.
Old 11-02-2009, 08:29 PM   #8
DezSlash's Avatar
To set you end points especially on the 8 take off your filter assembly and pull full throttle start backing of the end point untill you have a small amount closed. What i do for brake may be different for others but I start the car and run it full bore and start putting end point where the tires lock up on pavement. That is enought brake for me.
Companies I support
Arcor Raceway
Old 11-02-2009, 08:30 PM   #9
When you adjust your throttle, you want to adjust the end point while you are pulling full throttle, set your epa around 50% throttle, and with your airfilter off, see how far that opens your carb. If it opens all the way, then check to see if the carb is pulling on the motor and putting tension on it. If it is, then you lower your epa. If the slide carb is not fully opened, then increase the percentage until it opens all the way. After you have it open all the way, make sure the motor is not being pulled by the carb and servo at full throttle. You want the slide to open, but not to pull the entire motor. The easiest way to see it is if you put the truck on your starter box or something pretty solid. Pull the throttle and see if the cooling head moves. If it does, then you have too much throttle. If it stays put, then you are set. If you are just starting out and the track is pretty tame, lower you throttle epa so that the vehicle is more controllable. The only time you would want to have full power is if you have jumps where you need full power to clear. If this is the case, then you will need to learn throttle control while you learn to drive.
For the brakes, you don't want a full lock setup. You can either do this with the car running or not. I like to have the car running, drive it around and then at throttle, try to bring your car to a stop. It should not lock up your tires wildly. If you lock your tires up, then you may want to reduce the brake epa so that the vehicle comes to a little more controlled stop. This is easier on the servo and the car and makes it a little easier to drive.
Good luck and I hope this helps.
Old 11-02-2009, 08:34 PM   #10
Cory Kerber's Avatar
Once you learn how to properly set EPA, invest in a pair of Hitec 7955, 7950, or 7940 servos and you'll be good for the next... 10 years!!!!
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 11-02-2009, 08:41 PM   #11
Yup, everyone has their personal favorites. I used to run JR's but I really like the Hitec series alot. Plus hitec's customer service is top notch as well. JR's are good in my book, but the Hitecs are a little better spec wise and warranty wise as well. But these are just my opinion.
Old 11-02-2009, 08:43 PM   #12
Registered User
Thanks for all the replies, especially gotspeed_2000 concerning the setting of the endpoints. Frank L, you were right, the servo is contacting the mud guard wish I would have had a little more attention to detail, oh well, guess you gotta learn.
Old 11-03-2009, 08:11 AM   #13
if your buggy is set correctly you the buggy should not cause the servos to burn.... now what i have found drive LOSI for the last couple years is that I was buring servos not from the tray or chassis fault but my linkage was set wrong...... got that fixed and running hitec servos - no more DNFs because of servos...........
The spring on the throttle arm should not be compressed all the way.....
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 11-03-2009, 08:19 AM   #14
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
I had a 2.0B....my tx epa's and carb linkage setup was dialed and checked by all the fast guys at my track and I still managed to lose a HiTec 5955.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 11-03-2009, 08:56 AM   #15
jared52's Avatar
Hey Frank, how could you tell it was rubbing? I tried to look but I couldn't quite see. How much did you shave off?
jared52 is offline   Reply With Quote
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
