Old 11-02-2009, 01:23 PM   #1
Nitro F150's Avatar
Default How to warm up a nitro truck?
Im trying to break in my truck and cant get it started.
Nitro F150 is offline   Reply With Quote
Old 11-02-2009, 01:41 PM   #2
heat gun. remember, blow drier does not equal heat gun. put a foam or tin foil over the head to keep temps up. if it is cold in your area you might consider letting it idle in front of a space heater in addition to the initial application of heat to the block and head. obvioulsy make sure the space heater makes the ambient temperature around the truck about 75ish. no need to crank it all the way up and make the truck hot to the touch, just warm. cold weather break ins are very difficult.
C.Harper is offline   Reply With Quote
Old 11-02-2009, 01:44 PM   #3
cluffy1's Avatar
hey mate there are a few simple checks that you can do first get a blow drier and heat the crank case up before trying to start it. if you have done this you should check all fuel lines for leaks and make sure that the engine is getting fuel. if this i OK then check the glow plud located in the top of the engine and ensure it works by heating it up with your glow starter. if all of this is good and the car still doesn't go then you may have to go to your local hobby shop to get them to have a good look at it as it may be a far greater issue
hope this helps
dane
go hard or go home
cluffy1 is offline   Reply With Quote
Old 11-02-2009, 06:23 PM   #4
DezSlash's Avatar
Get a heat gun, warm up the motor including the case. I have one that has a nozzle the same size as my hole on the top of the head. I start with heat still applied then remove the heat. Then pinch is probally real tight. Also what kind of motor, are your settings correct, how you starting?
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 11-02-2009, 06:54 PM   #5
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
On the way to the track just put the buggy under the hood of the truck. Works every time
boomgagem is offline   Reply With Quote
Old 11-03-2009, 07:32 AM   #6
scwrod's Avatar
First question should be is this a new motor or one that has been run alot.
Need more details.....
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 11-06-2009, 03:57 PM   #7
xBRxSAIGON's Avatar
yup
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Old 11-06-2009, 03:58 PM   #8
xBRxSAIGON's Avatar
Heat gun.. I hate when they dont start right away.
Piks of your MEAN truck!!! ProudSavageOwnr Monster Trucks 2536 02-24-2017 07:01 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Want to instantly fry your Novak GTB Spread Spectrum? TeQ Radio and Electronics 189 05-14-2011 01:58 AM
Which monster truck to buy Brandon x Monster Trucks 51 04-13-2006 10:00 PM
Hello - New to everything RC demonheadx Rookie Zone 13 07-22-2005 10:12 PM
