I do have packages for lightening the chassis and drive parts IE: spur, outdrives and crown gears. PM me for the info, mods say I cant get into pricing on here
shawn
ADVANCED CUSTOM ENGINEERING.....custom components designed for racers, by racers!!!!! email acercparts@yahoo.com for info
http://photobucket.com/acercparts
Unfortunately the weather's been pretty good here in hawaii. . . The bad part is that work and my g/f's kids soccer season has kept me away from the track for about 2-3 months. Season is ending soon, so hopefully will have a small window to get some runs in. Hopefully things are doing better for you, especially with work and all. Thank you very much for doing all you do for D8/D8T owners. If you are ever in Hawaii, shoot us a pm before you come down.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
Got my shock towers for the D8T yesterday!! Cheehoo! thing looks sick!! Thanks Shawn!
Did you ever consider making the servo savor brace as well as the center diff top plate? would be sick to have everything matching.
Can anyone post some pics of his products? My computer is being a turd and won't open his photobucket account. I am taking ownership of a new D8 here shortly and would like to get some good parts for it. Thanks in advance.
Jesse
www.ogrchobbies.com
SC8E
Tekin RX8
HB D8
Byrons Fuels
Jesse
Ill get some pics posted on here when I get home from the shop
wieghts for the buggy towers are:
stock front: 22g
6mm front: 22g
stock rear: 23g
6mm rear: 26g
HB extended rear: 27g
6mm extended rear: 33g
there is some weight gain with the rear towers, but they were designed to be strong and not let you down.
chassis before milling is 390g after mill 305g
drivetrain milling nets about 30-35g weight loss
send me a plane ticket!!!!! the weather is getting pretty crappy here!!!! fortunately we have a new indoor nitro track to run on this winter. hopefully that will keep me sane when there's 3 feet of snow on the ground!!!!!!
Sorry Shawn, I'm a govt employee and we're getting furloughs. For now, it means more time to do things around the house, but soon it should add up to more play time too. Hope you are doing well, especially with your primary job. I know a couple months ago you were hitting some leaner times, but that it started to turn around a bit. If you ever have a chance to come down, you gotta see the track the guys here have put together. Right on the water front, and an awesome layout. Awesome pictures and good job on putting down the weight of parts you work on cause they look good too. I'm thinking I'm gonna need to send you some outdrives to work on cause the HB ones while light, have hollow shafts which are a concern to me. I'll pm you when I'm ready to send them to you for work. Thanks again.
