Old 11-01-2009, 03:24 PM   #1
pickle311's Avatar
Trader Rating: 31 (100%+)
Default How to remove a sleeve
I have a couple of motors that I can't get the sleeves out of. Every motor I've rebuilt in the past, the sleeve slid out with no problem. How are you guys getting them out?
pickle311 is offline   Reply With Quote
Old 11-01-2009, 03:40 PM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
I use a heat gun and heat the block (use hot pads or "Mechanics" kevlar gloves).
Typically a wooden popsicle stick through the exhaust port (or small plastic zip tie) and then gently turn the crankshaft; it will bump it out/up enough for you to pull it out with no problem. Just don't force it, if you're having to force it, heat it more.
*Sometimes* on older/less cared for engines there can be sever varnish between the liner/wall that makes it want to stay in. Use PB 'Blaster or WD40 (any reasonable solvent) and spray it up from the bottom around the sleeve and let it soak; then reheat and try again.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-01-2009, 03:53 PM   #3
Racecrafter's Avatar
Trader Rating: 25 (96%+)
+1 Very sound advice!
Another helper I use is a rubber expansion plug
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-01-2009, 05:53 PM   #4
pickle311's Avatar
Sounds good, thanks
Old 11-01-2009, 05:58 PM   #5
portyansky's Avatar
Trader Rating: 54 (100%+)
zip tie trick works like a charm 99% of the time without even heating the engine.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 11-01-2009, 06:28 PM   #6
jnslprd's Avatar
you can use the washer from a glow plug, the same way you would with the zip tie through the port. copper is softer and will not damage anything
jnslprd is offline   Reply With Quote
Old 11-01-2009, 06:49 PM   #7
cutoff crooked toothbrush end and push out from bottom
mp94u is offline   Reply With Quote
Old 11-06-2009, 04:10 PM   #8
xBRxSAIGON's Avatar
I just take a tiny flat head and be CAREFULLLL..
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Old 11-06-2009, 04:10 PM   #9
xBRxSAIGON's Avatar
REAL careful
Old 11-07-2009, 05:08 AM   #10
Roelof's Avatar
Send a message via ICQ to Roelof
And for the 1% when the zip tie snaps off you can use a corner tip of a towel
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
How to solder correctly (a not so brief lesson) marine6680 Radio and Electronics 542 06-07-2017 06:14 PM
How to remove button from sleeve brianr34 Nitro Off-Road 10 03-27-2008 06:57 PM
How to remove a connecting rod? aabrown Nitro Off-Road 25 09-26-2007 10:55 AM
