LRP28R Spec 3 Bearings.... >
Old 11-01-2009, 10:49 AM
MotoGod's Avatar
Trader Rating: 118 (100%+)
Default LRP28R Spec 3 Bearings....
Anyone have a part number on engine bearings for an LRP28R Spec 3? I can't seem to find the exploded parts view...or a bearing size anywhere, but I know it's out there!
EDIT: Nevermind! Found em 5 minutes after I made this post!
MotoGod is offline
Old 11-01-2009, 11:01 AM
MotoGod's Avatar
Hmmmm so I found the diagrams and got part number LRP 39293 for the bearing I need....but no one seems to have it for sale...not even AE?
MotoGod is offline
Old 11-01-2009, 01:07 PM
rotarynut's Avatar
Trader Rating: 30 (100%+)
this is the parts listings on TowerHobbies ,
http://www3.towerhobbies.com/cgi-bin...I=ASCG3281&P=Z it has listing for the rear bearing only, I found a bearing set from Boca Bearing http://www.bocabearings.com/main1.as...n=#ENK-005C-HP
the ft bearing size is 7x19x6 according to them, you might want to verify your actual bearing,I compared it to mine(engine not taken apart) it seems like it's the correct one though. also found this ,just in case you need it later on http://www.gohobbies.com/itemASC-LRP38237.html good luck.
rotarynut is offline
Old 11-02-2009, 03:07 AM
itsshemp's Avatar
Yeah dont bother with the stock bearing. They are junk, and cost about the same as the Boca ceramic. Boca was the only one I found that had the right size for the rear bearing. The front is a standard 7x19x6. I bought both ceramics from Boca for about 40.00 i think.
If you go with the Boca, remove the seals from the center bearing. It tells you about it in the instructions that come with the bearings.
itsshemp is offline
