Old 10-31-2009, 07:27 PM   #1
Default Cold engine temps???
Hello,
Iam running my buggy with a OS VZB in it. The outside temps are as such that the motor will only get to about 180 to 200deg.
Is that hard on it? It is broke in though.
Thanks.
Kevin.R is offline   Reply With Quote
Old 10-31-2009, 08:14 PM   #2
rider313's Avatar
Trader Rating: 94 (100%+)
rap you head in tin foil or with a 1/10 scale tire foam to keep the temps up.
rider313 is offline   Reply With Quote
Old 10-31-2009, 09:31 PM   #3
bustabo's Avatar
Trader Rating: 15 (83%+)
Send a message via AIM to bustabo
he is NOT talking about breaking the motor in.
bustabo is offline   Reply With Quote
Old 11-01-2009, 03:53 AM   #4
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
When its that cold that the engine can't get up to temp 180 is kinda bad. I would run a rag folded over once and cut to size to fit 1/2 to 1/3 over the front of the engine and zip tie it on there to keep the temps normal.
awdcameolsx is offline   Reply With Quote
Old 11-01-2009, 04:03 AM   #5
stoney1974's Avatar
Trader Rating: 11 (92%+)
i would lean it out until it is running about 220-230 running to cold will hut your con if you dont want to lean it get some alluminum tape and put it around your head
drive fast take chances
www.askrcracing.webs.com
crazy traction compound
stoney1974 is offline   Reply With Quote
Old 11-01-2009, 07:34 AM   #6
itsshemp's Avatar
Is it running good at those temps?
Tune to power. If it's running rich at 180-200 lean it out a bit. Outside ambient temp will effect the tune, but if it's running with usual power and just the temps are lower than normal I personally wouldn't worry about it.
Leaning it out will not only raise the temp, but will reduce lubrication. Not always a good thing. Some engines (GRP for example) run all day at 180-190 deg and does not hurt the conrod.
Just my $.02 .
Danny Flores
____________
Team Driver for:
Hot Bodies/HPI - Track Star Services - Triton R/C - Alpha Plus Engines - Radiopost - Hemet Competition Raceway (HCR) - Hemet R/C (R.I.P)
itsshemp is offline   Reply With Quote
Old 11-01-2009, 05:39 PM   #7
Hey thanks guys, I ran today and rapped just the top part of the head. It ran at 210-230, ran great.
Kevin.
just broke engine in with a liter of 20% is it ok now to tune with 30% dreaux Nitro Off-Road 6 05-02-2009 11:47 PM
Is it really hard on a engine to run in cold temps? hobdog Nitro Off-Road 39 12-21-2008 12:25 PM
S7 engine temps tubehead Nitro Off-Road 12 08-06-2007 03:42 PM
Higher nitro content = lower engine temps but.... Team Duratrax Electric Off-Road 9 08-15-2005 07:41 PM
What temperature do you run in cold weather(winter)? dino.tw Nitro On-Road 18 12-09-2003 02:35 PM
