Old 10-31-2009, 02:54 PM   #1
Nitro F150's Avatar
Default Is it bad to leave fuel iin car?
I have an nitro rustler and I just got a new engine and I started to break it in but it started to rain. I finished break in process 1.
Nitro F150 is offline   Reply With Quote
Old 10-31-2009, 03:01 PM   #2
Suspended
Trader Rating: 4 (83%+)
I would replace the fuel.
LosiDriver4Life is offline   Reply With Quote
Old 10-31-2009, 03:26 PM   #3
Zerodefect's Avatar
It takes more than 1 night to rust the insides of an engine, just fire it up tomarrow and run all of the fuel out of the engine.
If you run Sidewinder or Byrons you'll have little to worry about.
Zerodefect is offline   Reply With Quote
Old 10-31-2009, 03:30 PM   #4
Integra's Avatar
couple days MAX then you'll want to dump it....it will work...but ove time Will have slightly less power due to a lesser nitro content.
Old 10-31-2009, 03:38 PM   #5
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Not only that, but nitro fuel is very hydroscopic. It absorbs moisture very readily. This will lower performance and intrduce moisture to engine parts. You probably be chasing a tune for nothing while that fuel is in the tank. If its been more than 12-24 hours throw it away, even then it CAN be problematic. One of the reasons why you are supposed to use after run oil is due to the fuel left in the engine attracting moisture and rusting the internals. Nitro is much worse than gasoline about that.
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
Old 10-31-2009, 03:58 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
I use after run oil only if its going to be longer than a week before I fire it up again. Otherwise no probs here.
Old 10-31-2009, 06:55 PM   #7
AndrewClaycomb's Avatar
+1, I've even read that some think that after run oil is actually bad for your engine if you aren't storing it longer than a couple of weeks. Something about being bad for the bearings.
Tekno 8ight
Kyosho Ultima SC
AndrewClaycomb is offline   Reply With Quote
Old 10-31-2009, 10:51 PM   #8
losi_racer's Avatar
why post something thats not true. you need to state thats your opinion. our gas WILL NOT go bad that fast in our cars just sitting in a sealed tank, you dont want it sitting there for months but leaving fuel in a tank for a week or two wont hurt anything. I for one leave the fuel in my car. I race every weekend. I have never had any problems in the year ive been doing this, there has been times it sat there a month before i raced again no issues.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 11-01-2009, 05:15 AM   #9
Zerodefect's Avatar
I allawys try to pull my car in and run that last bit of fuel out while the car is sitting wheels up on the pit wall or my starter box.
That way the engine is nice and dry. No rusty alcohol on my bearings. byrons is pretty good at not rusting stuff. Morgans Sidewinder absolutely prevents rust like nothing I've ever seen. I don't even use ARO ever when I get to run Sidewinder.
The only time I use ARO is when my car get stroed for the winter. Before I box it up I rebuild the whole car including a complete engine teardown and lube its guts with RB ARO by hand.
ARO isn't very nice if it gets on your glow plug element or into your carb needles. Can mess up tune.
Old 11-01-2009, 08:31 AM   #10
This is what I use.
I use it for engine assembly and if the engine will sit for any period of time.
You could use Mineral Oil from a pharmacy.
I always run it out of fuel. It's fine like that for a short time. After that I use the above.
If your not going to use a engine for a while. Lube it and put it in a zip lock bag. Then trough some of those packs that come with shoes and electronics in. It will absorb moisture. Through the pack in the microwave ever once in awhile to dry it out again.
Chris Reilly is offline   Reply With Quote
Old 11-01-2009, 08:59 AM   #11
Madbrad's Avatar
Trader Rating: 29 (100%+)
Whats the difference between gas sitting in your tank and gas in the can/jug ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 11-01-2009, 09:09 AM   #12
Integra's Avatar
tank isn't 100% air tight...where as a Jug is.
Old 11-01-2009, 03:09 PM   #13
cary's Avatar
Trader Rating: 67 (100%+)
as far as fuel setting in the car or fuel bottle I had it explained to me
like this if you left a open beer setting out over night would you drink
it? NO so why would you make your expensive mill drink old fuel
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 11-01-2009, 03:55 PM   #14
Frank L's Avatar
I hate open beer. They are only good for so long. Thats a great way to put it.
