Old 10-31-2009, 07:12 AM   #1
Default O.S. Vspec Question
Can you put the sleeve piston and connecting rod from a speed into the regular vspec?
Twisted Nitro is offline   Reply With Quote
Old 10-31-2009, 07:22 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
Yes you can. Make sure you do the p/s/r all togeather Nd you will have everything but the speed crank.
Old 10-31-2009, 07:30 AM   #3
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
The basic different between those 2 pistons and sleeves is just the exhaust porting.(the speed has 2 elongations at either ends of the top) The connecting rod for the speed also has and oiling hole. The crank is the biggest part of what gives the speed its smoothness and amazing top end. So if that is your goal and your piston and sleeve are good a speed crank and rod would be your best bet to change.
awdcameolsx is offline   Reply With Quote
Old 10-31-2009, 07:33 AM   #4
Can you still use the standard crank with it.
Old 10-31-2009, 07:51 AM   #5
If the standard crank is in good shape, not worn out, out of round, then yes.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 10-31-2009, 08:47 AM   #6
The crank is in good shape. I just broke the piston being stupid.
Old 10-31-2009, 08:50 AM   #7
Can we use regular engine with Speed crank, speed c.rod with regular p/s ?
Hengfook is offline   Reply With Quote
Old 10-31-2009, 09:42 AM   #8
I guess now that I know it should work. Would it be worth the extra to by the speed piston sleeve and rod since I need to replace that stuff anyway.
Old 10-31-2009, 09:46 AM   #9
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Yes. And in my book its a better running combo than the speed p&s.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-31-2009, 11:39 AM   #10
Frank L's Avatar
Sometimes you can find the speed p/s/r already assembled i n a combo. I know I picked up a few NIB on the for sale side for 165.
Old 10-31-2009, 12:04 PM   #11
portyansky's Avatar
Trader Rating: 54 (100%+)
Or you can take your engine and send it in to AB mods and it will be better the the speed after you install ceramics
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 10-31-2009, 01:13 PM   #12
cary's Avatar
Trader Rating: 67 (100%+)
For what it is worth just buy a new speed. I have pretty much
done all of the above and it is not as good as a speed. The crank
is the hart of the whole thing by the time you get p/s/r and a crank
not to mention bearings you could have bout a new speed
just my two cents
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 10-31-2009, 02:45 PM   #13
I have a good standard crank brand new ceramic bearings(never even been started with them installed. I found a piston and sleeve and rod for a speed for a great price. For the difference from replacing it with the standard piston and sleeve and rod is the speed stuff that much better without the speed crank?
Old 10-31-2009, 06:37 PM   #14
I had a engine in the configuration your talking about. You will get a smidget more top end so you could either run a .5 smaller restrictor for run time but all the bottom end is gona feel the same. If the difference is only like 20 bucks then heck ya go for it. I always use speed rods personaly because they have the oiling hole, which in turn gives more life to the lower rod bushing and crank pin. So if that is your major difference in price it is well worth it.
Old 11-01-2009, 05:25 AM   #15
I just rebuilt a v-spec with speed crank, rod, p/s with ceramics and yes you can buy a speed for about the same money but I wanted the hands on experience and it was definitely rewarding but awful simple.
Joey Platinum is offline   Reply With Quote
O.S Engines thread TTR:EB4 Offroad Nitro Engine Forum 2421 08-17-2017 08:42 AM
opinions please! which is better the o.s speed vspec or the eb modded vspec? downunder23 Offroad Nitro Engine Forum 23 11-29-2015 02:37 PM
O.S. V-Spec needle settings Miniracer23 Nitro Off-Road 12 03-13-2010 05:58 PM
Question on O.S. Speed's jamiekerr14 Nitro Off-Road 56 06-22-2009 08:26 PM
Which pipe do you use for a vspec? Nitrorcracer Nitro Off-Road 19 01-08-2009 05:47 AM
