Old 11-01-2009, 06:22 AM   #16
Trader Rating: 25 (100%+)
Default V Spec/Speed combo
Hi guys, I have also tried the Speed liner in a V Spec and the engine runs fine but fuel economy will not be as good. The timing on the Speed crankshaft is done to match the advanced exhaust port timing on the Speed liner so when you use a Speed liner on a V Spec crank fuel economy suffers.
I have however used the V Spec liner with a Speed crankshaft and the low speed torque is awsome but again the fuel economy suffers.
I would not recomend using a Speed conrod on a V Spec crankshaft as the hole in the rod coupled with the hole in the crankshaft leaves not enough surface area for the oil film to do it's work which will result in even faster crankshaft wear.
Hope this helps.
Steve
smelly62 is offline   Reply With Quote
Old 11-01-2009, 07:34 AM   #17
Hope this helps.
Steve
Hengfook is offline   Reply With Quote
Old 11-01-2009, 09:54 AM   #18
Hope this helps.
Steve
Will the fuel economy be any worse than the standard sleeve with the standard crank?
Twisted Nitro is offline   Reply With Quote
O.S Engines thread TTR:EB4 Offroad Nitro Engine Forum 2421 08-17-2017 08:42 AM
opinions please! which is better the o.s speed vspec or the eb modded vspec? downunder23 Offroad Nitro Engine Forum 23 11-29-2015 02:37 PM
O.S. V-Spec needle settings Miniracer23 Nitro Off-Road 12 03-13-2010 05:58 PM
Question on O.S. Speed's jamiekerr14 Nitro Off-Road 56 06-22-2009 08:26 PM
Which pipe do you use for a vspec? Nitrorcracer Nitro Off-Road 19 01-08-2009 05:47 AM
