Old 10-30-2009, 06:34 PM   #1
JPKinsella's Avatar
Trader Rating: 30 (100%+)
Unhappy Losi 454 bearing help!
I was putting new clutch shoes on the fly wheel and noticed a wet residew behind the fly wheel. Took the fly wheel off and the front main bearing has been leaking fuel. Is it time to replace the bearing? The motor has about two gallons on it and the idle has been varing in speed but the middle and top end have been great. If new bearings what ones to go with.
JPKinsella is offline   Reply With Quote
Old 10-30-2009, 06:52 PM   #2
tc5 man's Avatar
i woulnt worry about it espially when the engine only has 2 gallons on it
its normal to have a little of a leak but not a whole lot it does it espilly when your engine is tune prety rich i have a nova thats on its 2 gallon and it does it and runs fine
Old 10-31-2009, 09:56 PM   #3
hdcruzer's Avatar
Sounds like you have a bad bearing seal. I have a 454 with about 5 gallons of gas through it and it dosnt leak or seap a drop.
hdcruzer is offline   Reply With Quote
Old 10-31-2009, 10:41 PM   #4
JPKinsella's Avatar
Yep and leaking air!!! New bearings on the way the rear bearing is a weird size boca was the only place I could find one. ceramics all the way!!!!!
