Old 10-30-2009, 12:22 PM   #1
THE GREEK FREAK's Avatar
Questions?? ENGINE BEARINGS
HELLO, I WOULD LIKE TO SOLVE A PROBLEM OF MY OWN. DO THE BEARINGS HAVE ANY ISSUE IN SEALING A NITRO ENGINE, BOTH IN AND OUT BEARINGS OF THE CRANK. DO WE HAVE TO CHANGE THE BEARINGS AFTER A CERTAIN PERIOD? DO THE BEARINGS IN ANY WAY SEAL THE ENGINE FROM ANY AIR LEAKS? THANK YOU.
THE GREEK FREAK is offline   Reply With Quote
Old 10-30-2009, 01:11 PM   #2
Racecrafter's Avatar
Trader Rating: 25 (96%+)
If you have a front bearing with a worn seal you will experience an air leak.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-30-2009, 07:03 PM   #3
bgbelden's Avatar
Even new bearings leak but a worn bearing will leak enough 2 cause idling issue's
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 10-30-2009, 07:07 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I find that high end TKO ceramic bearings last about 5 gallons. I never replace bearings with stock and some engine builders will advise to replace the front bearing every gallon, that seems a little excessive to me but that's what I have been told.
Old 10-31-2009, 09:29 AM   #5
Thumbs up
THANK YOU FOR ALL OF YOUR ADVICE. YOU GUYS WERE REALLY HELPFUL!!
Old 10-31-2009, 12:12 PM   #6
houston's Avatar
Trader Rating: 91 (100%+)
replace when they leak horribly ., dirt goes in and out of front bearings
every gallon may seem excessive for replacement but if the bearing leaks , the bearing leaks .
new bearings can leak as soon as you start using them but that does not mean they are leaking bad enough to cause tuning issues
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-31-2009, 02:29 PM   #7
Frank L's Avatar
That's exactly what I do when the front starts to leak I replace it. The rear will make strange noises and then I replace it as well.
Old 11-01-2009, 10:31 AM   #8
Thumbs up
THANKS AGAIN GREAT ADVICE. LET'S KEEP UP THE GOOD WORK!!
Old 11-01-2009, 06:37 PM   #9
houston's Avatar
tell tale sign for rear bearing issue is a funny rattling reverberating sound that is amplified by the cooling head . if you touch the head and it quiets down you might have an iffy rear main bearing
Old 11-01-2009, 08:46 PM   #10
Cory Kerber's Avatar
I've got a question Monty. My front bearing in my grenade seems to be leaking, but not tuning issues. After a dusty day of practice the bearing was coated in oiled dirt. Should i replace the bearing if it isn't giving tuning issues?
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 11-02-2009, 12:07 AM   #11
i wouldn't
I usually poke my fore finger and move it fore, aft, and sideways to check for play.
Talking about the rear bearing
cheapskate.brok is offline   Reply With Quote
Old 11-02-2009, 09:46 AM   #12
houston's Avatar
Not necessarily
But if it is leaving a good puddle of engine poo around the flywheel then you probably should .
There is really an engine named a grenade ?
Old 11-02-2009, 01:38 PM   #13
Not necessarily
Agreed!
And yes.... "Grenade".......... Only this one you throw after it blows up...
Actually I hear they are pretty darn good engines.
Jimmy Wright
Old 11-02-2009, 04:19 PM   #14
Agreed!
Yup Caster Grenade. Awesome engine, with extremely cheap parts. Similar to a Go engine.
*TEAM TERRIBLES*
Old 11-04-2009, 12:16 AM   #15
merdith6's Avatar
Default TKO or Nova bearings?
So the TKO bearings are good compared to the stock nova bearings? I've wanted to have some ceramic bearings in my engines, but never had a problem with stock ones either. The double shielded front bearings don't leak a bit. the older one sided ones did just slightly and never had an issue, now the rear bearing rattle sounds familiar, never knew what it was...Oopps...
merdith6 is offline   Reply With Quote
Tko Engine bearings vs Oem Novarossi bearings J.Gonzalez Nitro Off-Road 17 06-18-2009 08:25 PM
