Old 11-04-2009, 02:41 AM   #16
Originally Posted by merdith6 View Post
So the TKO bearings are good compared to the stock nova bearings? I've wanted to have some ceramic bearings in my engines, but never had a problem with stock ones either. The double shielded front bearings don't leak a bit. the older one sided ones did just slightly and never had an issue, now the rear bearing rattle sounds familiar, never knew what it was...Oopps...
The ones from TKO seem to vary the outer diameter by having thicker walls, instead of bigger balls (nova)
cheapskate.brok is offline   Reply With Quote
Old 11-04-2009, 05:21 AM   #17
j8ight13's Avatar
anyone know a good method to change bearings?
Team Losi/8ight 2.0-8ight-T 2.0 Hot Bodies/D8
Nova +4/ GRP MRT .21/GRP .21/GRP MRT .28/Ninja JX21/OS V-spec PROMOD
Hitec 7954HV,7955/ JR 9100s-t/ JR 8800s-t
GRP 2053, RE10, RE11, NOVA9901
DX3S/M11x
j8ight13 is offline   Reply With Quote
Old 11-04-2009, 05:15 PM   #18
n.e.r.d's Avatar
Just wondering..
Anyone tried Acer ceramic engine bearings?
Good price on them now so i bought front and rear bearings for my JX21.
Wanted to get some opinions b4 i replace the bearings.
I've received the bearings, front looks okay but doubts about the rear one.
The seal on the non-open end is kinda flimsy, does not sit right.
Able to move it around with my fingers.
One question, is it necessary for the rear bearing seal to be there?
I didn't think so cos imo the seal does not serve any purpose..
Thought of removing the seal b4 I pop it into the engine.
Any comments?
n.e.r.d is offline   Reply With Quote
Old 11-04-2009, 05:19 PM   #19
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by n.e.r.d View Post
Just wondering..
Any comments?
No reason whatsoever to have the rear bearing seal. The bearing is not keeping anything in or out. I know racers that remove the seal and run the rear bearing without a seal. So ok to remove as far as I am concerned.
Old 11-04-2009, 06:06 PM   #20
n.e.r.d's Avatar
Thanks FrankL for the quick reply..
Guess I'll take out the seal b4 installing the Acer bearing.
Now it's the durability question..
Old 11-04-2009, 06:14 PM   #21
KK-racing's Avatar
Just wondering..
Any comments?
I'm baffled, I've received mine 2 weeks ago and there's no seal at all on all the 3 main bearing I bought ??(which should be the case)
KK-racing is offline   Reply With Quote
Old 11-04-2009, 06:20 PM   #22
n.e.r.d's Avatar
Oi, what you doing here? So much free time no need to work huh?
My Acer rear bearing has the seal on one side just like in the pics..
But I doubt there's any use for it so will take out the seal.
Old 11-04-2009, 06:34 PM   #23
KK-racing's Avatar
Yo, that's part of the peek ball-cage to hold and space out the balls. You better leave them alone otherwise all the balls will roll to one side or drop out. This part is supposed to face the front with the balls facing rear. That's why you can't see this part in the original bearing looking into the engine crankcase and thought it's a seal.
Now I know why your nick is n.e.r.d !
Old 11-04-2009, 07:10 PM   #24
n.e.r.d's Avatar
Is that thing part of the cage?
If it is, then why is it movable left right and center when the cage is only rotating with the balls?
Nevermind, we'll discuss further when we meet up. Don't wanna hijack this thread..
Tko Engine bearings vs Oem Novarossi bearings J.Gonzalez Nitro Off-Road 17 06-18-2009 08:25 PM
