Old 10-29-2009, 05:51 AM   #1
Default Smelling diff oils
Hi all,
I have just stripped my car for a routine rebuild, and noticed that my diff oils stink!! Kind of like rotten eggs! They are black so are definatly ready for a change, but is the smell normal?
I cannot remember if they smelt like this on my last car, but this is the first time I have stripped my 801XT to redo diffs.
So basically, is it normal for the diff ols to smell? If not then how do I change it?
Scott
lazyboy12300 is offline   Reply With Quote
Old 10-29-2009, 06:27 AM   #2
shanty140's Avatar
Actually this is something I noticed to when rebuilding my cars. You are not the only one.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 10-29-2009, 06:34 AM   #3
w_kirk_jr's Avatar
Send a message via Yahoo to w_kirk_jr
it is a good idea to change your diff and shock oils ever couple weekends atleast i redo then every week and redo my shocks befor every main and if i have time my diffs alos it is a good habit to get into so things domt weare as much and the car will handel more consistantly
WILLIAM KIRK JR-
WWW.DIXONSRCRACEWAY.COM | SIDEWINDER | TEAM EPIC | A-MAIN HOBBIES
WWW.MYHOBBYDEPOT.COM
push aginst me! It only will make me stronger and faster-
w_kirk_jr is offline   Reply With Quote
Old 10-29-2009, 07:24 AM   #4
shanty140's Avatar
I change my diff oils on average every 2-3 races which is more frequent compared to alot of people.. It doesn't smell bad enough to clear out a room, but definitely has a smell.
Race Vehicles:
Old 10-29-2009, 08:45 AM   #5
Zerodefect's Avatar
I mix axe body spray with my diff fluid to keep them from geting too stinky.
Diff fluid should be changed before it gets cooked. I use the AE fluid it seems to work well and is cheaper than Mugen/Kyosho. Ofna fluid didn't work too well for me.
Zerodefect is offline   Reply With Quote
Old 10-29-2009, 09:16 AM   #6
Lonestar's Avatar
yep - same here, they stink pretty badly, even after a "normal" use period (say, 2 hrs). I don't think it's just about the silicone "cooking" but rather about outside organic matter getting in (would be the case if you run in natural dirt with a lot of fine dust like my hometrack) and then contaminating the oil, further helped by the heat of course. Typically, smell goes with brownish/dirty looking oil.
Interestingly enough, the shock oil doesn't stink... and is clear in most cases, except the left rear.
You are NOT the only one. Be reassured.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-29-2009, 02:38 PM   #7
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by lazyboy12300 View Post
Hi all,
Scott
Scott,
What you are smelling is normal for "cooked" Silicone fluid. Especially on the Tamiya's the rear diff runs quite a bit hotter than the front or center. I pull my diffs down every weekend and just peak inside. If the fluid smells or looks to be tuning grey I will change it. If the next weekend after changing fluid it looks grey again, I will change the Sun & Spider gears.
Jimmy Wright
TRF
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-29-2009, 03:01 PM   #8
thanks for all the tips. Think i will just start changing diff oil more often.
Thanks for all the help
Scott
Old 10-29-2009, 04:00 PM   #9
+1 on the axe that stuff is awesome!
Joey Platinum is offline   Reply With Quote
Old 10-29-2009, 04:04 PM   #10
Trader Rating: 29 (100%+)
i mix a little bit of febreeze in mine and they smell great at the track! tons of people compliment the smell of my diffs! i personally like the berry smell best
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 10-29-2009, 04:16 PM   #11
Did you guys see the ad at the bottom of the page??....WTF... Why not leave it be, at least that way you can tell where it is. Don't doctor it up .com
Old 10-29-2009, 04:18 PM   #12
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Yep the smell is defiantly normal. I am sure I am not the only one who noticed but the thinner oils go bad/leak out faster. I keep a chart on my maintenance. for diff oils in my little notebook I carry. I change fluids 1-4k every 1.5 hours 5-7k every 2.5 hours and 8+ every 3 hours. Of course I am not perfect and blow past those times alot but if its been over that time I change them. But I always change them before a trophy race.
awdcameolsx is offline   Reply With Quote
Old 10-29-2009, 04:20 PM   #13
This junk is for real.
Old 10-29-2009, 04:27 PM   #14
bump
Old 10-29-2009, 04:35 PM   #15
Trader Rating: 21 (100%+)
Darn, Joey, its gone this time. These ads change from one time to the next.....
I wanted to click it and see what else it said....
Duster_360 is offline   Reply With Quote
