Old 10-30-2009, 03:11 AM   #16
LunchboX3904's Avatar
cool i haven't heard of the acetone method. so you just put an inch or so of acetone at the bottom of a coffee tin, have the wheel propped up above the liquid and seal 'er up for a day or two?
i forgot to cut my foams and my rear tires wobble like crazy, so would all three parts (tires, foam, and rim) be ok after using the acetone method? i ask because i used the boil method once and it was a huge pain in the butt and ended up warping/ruining the tires (probably my fault for trying to peel them away too soon ).
:: Associated T4 :: Associated SC10 :: Durango DESC410R :: HPI Blitz :: Tamiya TA-05 EGR Converted Drift Car ::
LunchboX3904 is offline   Reply With Quote
Old 10-30-2009, 06:53 AM   #17
Integra's Avatar
you got it bud.....give it time and they will come off.....Different glue's have different holding strength...some are a Biatch to get off....some pop off like they weren't even glued on....take your time and you'll be impressed with the results.
Old 10-30-2009, 07:01 AM   #18
Trader Rating: 26 (100%+)
So do you guys cut your AKA foams out before using acetone?
bphil49 is offline   Reply With Quote
Old 10-30-2009, 07:12 AM   #19
Integra's Avatar
depends what your trying to save.....if the tires are Toast ya just cut them off.
Old 10-30-2009, 03:33 PM   #20
offroad racer's Avatar
Originally Posted by rotarynut View Post
hey guys FYI, we are all using the primary solvent for CA glue and don't even know it, look @ this link and read under "uses", I little info goes a long way
someone give it a try and report the outcome
http://en.wikipedia.org/wiki/Nitromethane
Sweet
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 10-30-2009, 10:42 PM   #21
aaron joy's Avatar
Trader Rating: 16 (94%+)
I just removed 3 sets of rims that were soaking for about 3 weeks in a $7.00 plastic sealed bucket. The acetone was already old, brown and dirty. Rims that were not even in the acetone, the tires came right off with NO glue residue.
I reuse my AKA foams, you save like $20 on a set buying new AKAs' without the foam inserts.
aaron joy is offline   Reply With Quote
Old 10-31-2009, 04:32 AM   #22
Has anyone tried the nitro way yet? I want to hear how it works out for you.
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
Old 10-31-2009, 06:52 AM   #23
What I meant was will the acetone hurt the AKA foams?
Old 10-31-2009, 09:56 AM   #24
rider313's Avatar
Trader Rating: 94 (100%+)
what would be the bestt way to save the tires and foams, i got a set of aka cityblocks and the wheel hexes are stripped on two of the wheels but the tires have maybe one run on them so i want to save the tires and foams, rims are junk.
rider313 is offline   Reply With Quote
Old 10-31-2009, 02:37 PM   #25
Integra's Avatar
Acetone but not submerge...let the fume's do their work.
Old 10-31-2009, 02:53 PM   #26
rider313's Avatar
k thanks. i will let them sit for a few days.
Old 11-01-2009, 07:42 AM   #27
itsshemp's Avatar
I cut the tires, and remove the AKA foams before i throw them in the acetone. Over night should do the trick.
I cut the rubber off only leaving the bead attached to the wheel, then fit as many as I can in the container im using, and soak overnight. Normally the rubber ring will just come right off.
If your using a molded foam, the acetone will more than likely eat up the foam. The tires will be OK though.
Danny Flores
____________
Team Driver for:
Hot Bodies/HPI - Track Star Services - Triton R/C - Alpha Plus Engines - Radiopost - Hemet Competition Raceway (HCR) - Hemet R/C (R.I.P)
itsshemp is offline   Reply With Quote
Old 11-01-2009, 09:05 AM   #28
Integra's Avatar
he is wanting to save the tire's and foams...the hex's he said are stripped out...IF the tire was gone and all you wanted was the foam and rim then by all means cutting them off is a lot easier then not.
Old 11-04-2009, 03:29 PM   #29
Trader Rating: 24 (100%+)
OK, the acetone fumes worked great, but what's the best way to clean the glue off the rest of the rims?
Thx.
JodyJ is offline   Reply With Quote
Old 11-04-2009, 04:08 PM   #30
rider313's Avatar
Thx.
if it dries take a dremel with a wire wheel to it.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
AKA tires ALG Nitro Off-Road 1793 11-04-2016 06:37 AM
how to remove rubber tires already glued on rims? Molala3 Electric On-Road 34 05-11-2016 09:33 AM
What tires? Dredd Nitro On-Road 17 01-13-2007 04:21 PM
NEED HELP>getting glued tires off of plastic rims old_fart_racing Electric Off-Road 16 09-21-2006 09:13 PM
