Old 10-28-2009, 03:32 PM   #1
yfzracer912's Avatar
Default Which hinge pin reamer for 8ight?
I want to get a hing pin reamer but what size do I need for the a-arms on my losi 8ight 2.0?
yfzracer912 is offline   Reply With Quote
Old 10-28-2009, 06:12 PM   #2
Trader Rating: 28 (100%+)
I use the hudy ones. The 4mm one for the inner pins and the 3.5mm one for the rear outter pins. I know there are other companys out there that make them but you can't go wrong with the hudy tools imo.
8secnotch is offline   Reply With Quote
Old 10-28-2009, 09:14 PM   #3
aaron joy's Avatar
Trader Rating: 16 (94%+)
You can save yourself alot of money by just going to your local hardware store and buying some drill bits for under a dollar each.
aaron joy is offline   Reply With Quote
Old 10-29-2009, 07:59 AM   #4
shady3031's Avatar
Trader Rating: 26 (100%+)
+1 Plus they seem to work better. The only one I've ever needed was the 4.1mm for the inner 4mm hinge pin
The Warehouse RC-Birmingham, AL
AE RC8.2-E Tekin powered
Alabama Manufacturers Shootout-Don't Miss It
shady3031 is offline   Reply With Quote
Old 10-30-2009, 02:23 PM   #5
So what size drill bits do I need?
Old 10-30-2009, 10:35 PM   #6
aaron joy's Avatar
For the inner I use a #19 drill bit which equals 4.216 (only because I found it laying around in my drill bit drawer and test fitted it)
for inner
gauge inches mm
20 0.161 4.089
19 0.166 4.216
for outer rear
gauge inches mm
28 0.1405 3.569
Here is a link to wikipedia on drill bit size with conversions:
http://en.wikipedia.org/wiki/Drill_bit_sizes
Old 10-30-2009, 10:59 PM   #7
What are these reamers used for? Sorry if this is a dumb question.
matrixmike28 is offline   Reply With Quote
Old 10-30-2009, 11:09 PM   #8
It removes the material to the size of the reamer. Used to make sure the suspension arms move freely. Just make sure you use the right size. After you remove the material you can put it back.
Chris Reilly is offline   Reply With Quote
Loaded losi 8ight raceroller. jpz_67 R/C Items: For Sale/Trade 9 06-18-2008 06:35 AM
