Old 10-28-2009, 03:19 PM   #1
Madbrad's Avatar
Trader Rating: 29 (100%+)
Default Does such a started box exists?
Is there a starter box that can be adjusted easily and quickly to fit different chassis? I can move the mounts on mine now but it take a little work to move them each time, just wondering if any ones found a way to do this.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 10-28-2009, 04:41 PM   #2
slaytanic's Avatar
Trader Rating: 20 (95%+)
http://www.tonysscrews.com/product.s...&categoryId=75
Try these. They allow you to set up a box for truggy and buggy. They are retractable buttons. If you run two very different chassis you can get 2 sets for front and back.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 10-29-2009, 12:50 AM   #3
Trader Rating: 19 (100%+)
A few very clever individuals where I am have got a "top plate" arrangement for their starter boxes. Here's what you do.
1) On your starter box set the pins where you want (doens't matter where) and it helps at this stage to take the top "lid" of your box comepltey off your starte box which will make the following tasks a lot easier.
2) Get a piece of ply wood, or perspex, and drill holes that match the pins you positioned in task 1. Note that a thinner material is more ideal, as it will be less of a hinderance when you get to task 7. The material doesn't really need to be strong, because all this piece of wood/plastic will do is sit on the top of your box. It's not going to hold up your car or anything.
3) Now you will have a sheet of ply wood sitting perfectly on your starter box lid.
4) Cut the hole out of the piece of wood to allow the rubber wheel to push through the ply wood.
5) place your starter box lid (with the piece of ply wood on it) back onto your starter box and line up your buggy on the piece of ply wood, making sure it lines up with the rubber starter wheel.
6) insert pins in your ply wood (generally a piece of dowel is good for this) to seat your buggy nicely on the piece of ply wood.
7) fix your starter box lid back onto starter box, and check that the rubber wheel doesn't get obstructed by the box itself when you push the lid down. You may need to cut a bit more out of the actual starter box lid, because the rubber wheel may not reach high enough to touch your cars fly wheel with the piece of ply wood in between.
Now to fit your truggy, basically make another piece of ply wood, and at task number 5, mark your pins out for your truggy. So now you will have one piece of ply wood for your buggy, and one for you truggy. You jsut swap that top piece of ply wood depending on what car you are starting.
Again, this idea is what some folks at my local club use... i saw it and thought it was a great idea !!!
You could try that out if you're up for it.
Cheers
LordAnubis is offline   Reply With Quote
Old 10-29-2009, 07:14 AM   #4
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Cheers
Hi, can you show us some pic? Thanks in advance.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 10-29-2009, 09:47 AM   #5
Madbrad's Avatar
Good idea's.
I also found this on youtube. Looks like good idea.
http://www.youtube.com/watch?v=SULZ_c6oXCg
Any one have an idea of what type of metal that person on youtube made those brakets out of ?
XT8 - Werks B5
Old 10-29-2009, 02:51 PM   #6
Trader Rating: 32 (100%+)
home depot sell L shaped aluminum that works perfor this for a few bucks. I made it for my ofna starter box.
Z01B | Xerun 150A 2000kv | Hitec | Desire-power 6S LiPo
Z01T | Tekin RX8 1700kv | Hitec | Desire-power 6S LiPo
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 10-29-2009, 02:53 PM   #7
wish someone would come out with a hand held version using same concept and a strong brushleess motor.
as long as it can start a broken in motor it would be sweet.
Old 10-29-2009, 06:19 PM   #8
Madbrad's Avatar
So how is it working for you ? How long ago did you do it and does it really work on all chassis ?
XT8 - Werks B5
Old 10-29-2009, 07:48 PM   #9
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
dont try to refuel the car on the starter box if you use this method
my mate uses this system and he keeps knocking the flywheel when he refuels and wastes time restarting it
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 10-30-2009, 03:36 AM   #10
Default great idea
Originally Posted by Madbrad View Post
Good idea's.
need some one to do it for me now. anyone tried this yet?
muaythai is offline   Reply With Quote
