throttle servo crash >
Old 10-28-2009, 07:57 AM
Default throttle servo crash
hi,just bought a 2.4 ghz transmitter but i lost 3 throttle servo (scanner rc,hitec and futaba) the servo stop operating after approx 15 mins of usage, everything was ok with my 3PM 75hz.
can somebody please help me in finding where the fault is.thx
blkorchid9 is offline
Old 10-28-2009, 08:01 AM
Madbrad's Avatar
Trader Rating: 30 (100%+)
Did you set your end points ? Is there any binding with the linkage ?
If your killing servos that fast, it almost has to be a setup issue.
Madbrad is offline
Old 10-28-2009, 08:14 AM
shanty140's Avatar
yup I agree with the top post, there has to be something wrong with your setup it would seem. What seems to be going on the servo's, something electrical or physical like the gears. Also what servos are you using. If they are really cheap they may not be able to handle what you are putting them through.
shanty140 is offline
Old 10-28-2009, 08:21 AM
Zerodefect's Avatar
Deos the T servo come back to life later on?
Have seen many increase EPA on the brakes to help stop the car as the brakes age. The servo can only pull so hard before it burns up. If your brakes are too worn or slick the servo has to pull too hard to stop the car.
Also make sure your rubber mounted and not screwed down too tight, and shim the servo so its about 3mm off the chassis. Don't let it get too close to the chassis.
If your running a Losi, upgrade to a carbon fibre radio tray.
Zerodefect is offline
Old 10-28-2009, 08:35 AM
asw7576's Avatar
Are those servos analog ?
Analog servos don't mix with latest receivers ( hrs, gigahertz ).
Use digital servos for latest receivers ( hopefully from same brand for less headache ).
asw7576 is offline
Old 10-28-2009, 10:27 AM
DezSlash's Avatar
Sounds like a epa and binding issue.What tx are you using and servo's? A 3PK will run analog servo's as long as it's not in HRS mode.
DezSlash is offline
Old 10-28-2009, 11:19 AM
ok guys i'll try to reset the transmitter and start set up again.But do you think that the receiver could cause these problems
thanks to all
cheers
Old 10-28-2009, 11:21 AM
aaron joy's Avatar
Trader Rating: 17 (95%+)
There is nothing wrong with running analog servos with newer receivers.
Just as DezSlash said as long as you don't run them in a "High Response" mode.
I run a 4yr old Airtronics analog 94359Z with my Futaba 4pk with no problems.
aaron joy is offline
