Old 10-27-2009, 05:10 PM   #1
hdcruzer's Avatar
Default Tire Question
How many of you guys have run The proline bowties in rear and the pro line holeshots up front and what kind of success did you have. Im talking the soft compound. I have a race Sat and was thinking about trying this but not going to have much time to practice before race. Thanks Rick
hdcruzer is offline   Reply With Quote
Old 10-27-2009, 05:12 PM   #2
DPowers's Avatar
Trader Rating: 79 (100%+)
i have run bowties in the back and crimefighter in the front (bowfighters) and that works really together.
DPowers is offline   Reply With Quote
Old 10-27-2009, 05:19 PM   #3
tc5 man's Avatar
the bowties would work good in the rear or the front the holeshots in the front proberty would take a lot of foward grip out and steering also thats my guess
Old 10-27-2009, 06:15 PM   #4
hdcruzer's Avatar
Okay let me ask this. How do the soft Hole shots work on a hard and dusty service. Ive used the boe ties and theres almost to much bite. I do have a set of the hard rubber crimefighters but there the older discountined version. Small rim and large tire. They work good but theres a lot of body roll
Old 10-27-2009, 06:19 PM   #5
I've used soft Double Dee's(pretty much a Holeshot) on hard packed dusty surface and it worked pretty well. Just don't get off the groove or you'll be skating.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 10-27-2009, 09:58 PM   #6
I have had very good luck with M3 revolvers with AKA or the new blue Pro-Line inserts on just about every surface, including hard and dusty. I have found the stock inserts in revolvers to make the car very unpredictable, but with a stiffer insert, the tire comes to life. Calibers also work well on that type of surface. If the track is really dusty out of the groove, you might not want to go with the hole shots, like Miniracer said, you'll be skating.
Hope this helps,
Chris
www.crgraphicsonline.com - like us on Facebook!
Trains and Lanes Hobbies - Answer RC USA - Mugen Seiki Racing - KJ RC Supply - Fioroni USA - First Turn Racing
cfr7 is offline   Reply With Quote
Old 10-27-2009, 10:03 PM   #7
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
I think it would work rather well on a really well groomed hard packed blue grooved track. However, you will run into a real wear issue with the rear tires.
On a different note I have run Double Dees on the rear of my buggy and Crowbars on the front of my car just to try on a crazy blue grooved track with amazing success. Definitely take a look at that setup. BTW JCONCEPTS rules.
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 10-28-2009, 04:53 PM   #8
Send a message via AIM to ShawnP Send a message via MSN to ShawnP Send a message via Yahoo to ShawnP
Ive found HoleShots to be excellent on blue groove... Like stated before get out of the groove though and you are on ice. BowFighters work well for me too...
ShawnP is offline   Reply With Quote
Old 10-28-2009, 05:06 PM   #9
climbaatizept's Avatar
+1
I often use this combination and i quite like the results
Kyosho MP9 / Team Durango DEX210 / Team Durango DEX410 / Hyper Rally Game / Truggy
Alpha Engiines / Schepis Model Engines /Multiplex /Spektrum /Runner Time Nitro
climbaatizept is offline   Reply With Quote
Old 10-28-2009, 09:14 PM   #10
Razathorn's Avatar
If your track is hard and dusty, the last thing you want is a soft compound tire in 1/8 scale imho -- unless your track is moist and dusty... which is strange to me. When you're on a dry surface, you want mediums, perhaps hard if it's really hot. Soft will not stick as well and will get destroyed, especially holeshots, on a dry dusty track. Now if it groves up, you may find that soft holeshots works well, but damn, I'd rather run mediums because they stick to the groove very well and will at least last a while -- I'd also run a slightly larger pin. I'm a big fan of medium jconcept hitmen and aka I-beams (like bowties).
The only time I'd run soft holeshots is when there's a moist pack -- they'd be absolutely dialed then.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-29-2009, 08:50 AM   #11
fatdaddy's Avatar
Originally Posted by climbaatizept View Post
+1
+2 i use this setup all the time
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Truggy Tire Question 2fst2c Nitro Off-Road 13 10-06-2009 01:03 PM
Rubber Tire Question CREWMAN Electric On-Road 10 06-04-2008 09:52 AM
Pro Line Edge Truck tire question K_King Electric Off-Road 6 04-18-2007 12:35 AM
Ellegi foam tire question maximebeauvais Electric On-Road 7 06-08-2006 07:23 AM
