Tune pipe comparison
This is a great question. I have been wondering the same thing for a long time. Does the EFRA number mean anything? Like is the lower numbers set for lower range pipes? like a 2013 is more low end and 2086 is more high end or is this just a coincidence?
Each engine has maybe 3-4 different pipes that work well with them.
The EFRA numbers are just an approval number. Said number no matter the manufacture must be built the same to hold that approval number.
There are some good pipes out there that are universal for many engines but are not optimal for performance or mileage.
Dependant on what engine you are running I'm sure many here can give you advice and help from their experience.
most times man. will list a pipe with performance description which is not always the exact description . what one pipe may do well with one engine might be very different on another brand.
i can tell you for the most part what pipes work well with most all novarossi engines
hi jimmy
stay cool
A Jammin JP2 or JP3 are probably the best pipe you can buy for any engine, in my opinion.
I want to see a cutaway view of different pipes.
I cary an os 2060, dyn 053, dyn 086 and trinity bad boy pipe. The 053 will work on almost any engine it's not the top end pipe but it usually works verywell. On os engines the os 2060 (efra 2042) isthe only pipe to have great power and great mileage. The trinity pipe has only seen a tank or 2 I personally don't like it. I know guys who run them but not me.
If someone asked me "I need a race pipe and have no idea what .21 engine I have....." I would say to use the JP2 or 3. They work on everything that I've seen.
Not the greatest performing pipe and far from being the most efficient....but,
Kinda have to agree here. I've ran the 053 on my Toro Nero and my V-spec. And by brother runs one on his speed and it seems to work well on them all. Recently switched to the 086 on my Toro and liked it even better.
I carry a 086, 053, 2013, and 2035 everywhere. Between those 4 I feel like I can cover any motor that I may run.
I also run the jp's I have a jp4 on my v spec and I get great mileage, but the top end is a little lite. What I was after was a break down on each pipe and what each one was suppose to do. Like how the dynamite pipe's are set up the 007 is high speed and so on. Or even a list that gives cross reference of numbers like the os 2060 is close to the same as a ???
I can tell you that as far as Dynamite goes
007= low end
053= mid range
086= High end
JP1= low
JP2= High
JP3= more all around tune
JP4= similar to the JP3 with an EFRA rating
007= low end
053= mid range
086= High end
JP1= low
JP2= High
