Old 10-27-2009, 07:54 PM   #31
tc5 man's Avatar
thats what i do to measure droop by using the calibers
Old 10-27-2009, 08:38 PM   #32
Lets say I had a really close set-up from some really good eyeballs...OK.I has gotten lots of practice w/ that set-up...OK. Then "Grouchy" does me a favor and sets my car up on his Hudy, and actually puts in positive camber,by mistake of course. Could that make my car feel un-controllable ...especially when I am used to running the peepee out of it???? I am not kidding I thought my vision was off... I thought me equilibrium was off, maybe I was coming down with a brain tumor.... I was completely baffled.I watched him set my car up and I was not going to question the set-up. I blamed it on me and the tires.i am convinced that you can get extremely accurate measurements with the Hudy. i also think that you need to compensate for the difference to get the final degrees of neg.camber to be correct.I appreciate anything that someone does for me.I am always willing to help anyone out.
Joey Platinum is offline   Reply With Quote
Old 10-28-2009, 03:21 AM   #33
Zerodefect's Avatar
Yes that would seriously screw the car up. If I use too little camber my car will flip over in every turn once the dust and marbles are blown off the track. Too much camber and it starts to act funny (makes baloon animals and squirts people with a plastic flower).
Everyone makes mistakes. Got to double check camber at ride ht and cycle the suspension and watch how the camber move when the chassis is moved up and down.
It's also handy to roll the car while in the station to see if you get positive camber on the outside rear as the car leans. I know about how much my car rolls, so I lean it over and watch the gauges.
You can also turn your steering and see your front camber changes and leans into the turn as you steer due to the cars caster and kickup angles.
Still I dont think -1 is enough. Use at least -2.5 in the rear. -3/-4 set at 30mm ht (30mm blocks) should do it. It'll be less at ride ht. Set droop to -2/-3 on the RC8.
Zerodefect is offline   Reply With Quote
Old 10-28-2009, 03:46 AM   #34
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
I understand the theory of using the blocks to get a consistant measurement.
But if i want to change my ride height then my camber will change. I dont know if there is an easy way to tell what your camber will be after you remove the blocks so i took the easy step and threw the blocks away.
Ever since i gave them the flick its made setting up my car a breeze
I just set my ride height with the wheels on, put it on the setup station and do the front and rear camber, do the front to and re check the front camber, take it off the setup station, sit it on the wheels and set the droop by the shock length.
I can do both my buggy and truggy in 20 minutes.
so now when i want to change my ride height i just re set my camber at that ride height
The blocks always confused me and everyone else i know. i dont know anyone who uses them anymore for offroad
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 10-28-2009, 03:47 AM   #35
Lille-bror's Avatar
Originally Posted by Zerodefect View Post
And they set the block too far back in that pic, its touching the arms.
Hi. Yeps, that's correct.
Here is how it should be (from Hudy┤s set-up guide):
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 10-28-2009, 06:22 AM   #36
PTP Racing's Avatar
There is one thing that is undeniable Hudy makes some cool looking stuff.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Have any tips for a guy moving from electric to nitro? Banter Nitro Off-Road 32 01-22-2009 02:19 PM
Thinking abot going lipo and don`t know a thing about them . Briguy Electric Off-Road 14 08-16-2008 04:16 PM
I know this has been posted 10,000 times... new to rc cars Nitro Off-Road 61 07-10-2008 04:21 PM
Anyone know a Deborah Henn? What do you think of this? XMSRacing Chat Lounge 40 01-12-2007 07:21 AM
I Know its Early, but lets start a thread on theTricities +??? cclifton Canadian R/C Scene 223 11-15-2004 10:44 AM
b4 or xxx ke2 -I know this has been asked a million times... AE Racer Electric Off-Road 132 01-11-2004 09:46 AM
