Old 10-27-2009, 05:32 PM   #31
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
as for the bits, I would highly recommend the MIP bits, they have the slot to lock in place and I have done tear downs and rebuilds with the same 2.0 and 2.5 bits for over a year and the hex still looks like new, no signs of wear.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 10-27-2009, 07:13 PM   #32
fatdaddy's Avatar
Originally Posted by beginner4life View Post
I know metric=mm but i just want to make sure these are right for an RC8T.
http://www.amainhobbies.com/product_...40-58-Phillips
if the assoicated uses metric hardware then thats the one you want. i dont know, but you man want to look into a bigger set that has the 1.5mm bit. does the rc8 have any 1.5 screws?
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 10-27-2009, 07:34 PM   #33
Integra's Avatar
IMO you dont need a Power driver for 1.5mm screw's....you'll only end up snapping the tip or stripping the part you screwing into......i cant say ive EVER used the 1.5 tip
Fatdaddy Almost every car will have 1.5 on them as thats the size of the linkage stopper set screw's...what Nitro powered rc doesn't have linkages right....but i still say you dont need a speed tip in 1.5mm
Old 10-27-2009, 07:45 PM   #34
Originally Posted by diamondracing View Post
If you can swing $100.00 plus tax this is hands down the best RC tool I own
http://www.amazon.com/Milwaukee-2401.../dp/B000WI9CIG
+1 I have had one of them for 6 months and i think i have charged it 3 times I like it real well.
axle is offline   Reply With Quote
Old 10-27-2009, 07:54 PM   #35
Integra's Avatar
2lbs Vs .5lb
that's how i look at this debate.
if your spending 100$ the Hitachi is IMO the only way to go.
IF you want to be able to use the drill for more then Just RC...then go with a pistol style like the Milwaukee or Makita.....i personally use the Makita for lots of thing's around the house and the Impact gun i got in the kit is also handy to have for stubborn knurled wheel nuts that dont want to come off (Nascar style)
Old 10-27-2009, 08:07 PM   #36
bustabo's Avatar
Trader Rating: 15 (83%+)
Send a message via AIM to bustabo
i have been using the Bosch 1ANU2. works mint, clutch is dialed, and has a led.
http://www.google.com/products/catal...077&sa=title#p
bustabo is offline   Reply With Quote
Old 10-27-2009, 09:07 PM   #37
sugs's Avatar
I've been using this Milwaukee cordless screwdriver for a long time. Gotta be getting close to 10 years old and only recently did one of the battery packs die. Very small and light.
http://www.milwaukeetool.com/Product...3aScrewdrivers
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 10-27-2009, 10:31 PM   #38
houston's Avatar
Trader Rating: 91 (100%+)
http://www.integy.com/st_main.html?p..._display&page=
look through this page
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-28-2009, 12:04 PM   #39
beginner4life's Avatar
Trader Rating: 9 (91%+)
Originally Posted by houston View Post
its the quickpit ones right?
About the 1.5mm, i was planning on just using a standard hex wrench since theyre so small.
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 10-28-2009, 01:23 PM   #40
noR
noR's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to noR Send a message via MSN to noR Send a message via Yahoo to noR
Better not be fibbin' houston.
I picked this up yesterday:
Ti-Nitride QuickPit 11pcs Set, Metric Allen Hex + Socket + Screw Driver Tips
Beginner4Life:
The Quick Pit & V-Torque line seems to support the chuck that clamps on.
QP: http://integy.com/st_prod.html?p_pro...35&p_catid=161
VT: http://integy.com/st_prod.html?p_pro...38&p_catid=161
Whereas their 4-in-1 seems to just be a normal 1/4" hex end.
http://integy.com/st_prod.html?p_pro...46&p_catid=161
Also MIP speed bits have the accommodations for the chuck as well.
http://www.miponline.com/MIP/STWrench.html
Check out my local track --> http://trackseeker.lefora.com/2009/05/01/trackseekers-18-scale-offroad-track-04302009/page1
noR is offline   Reply With Quote
Old 10-28-2009, 01:28 PM   #41
houston's Avatar
as far as the 1/16th and 1.5mm , the integy set comes with a handle so you can screw small stuff or finish off bolts/screws manually with the same tip .
been using the setup for about 3 yrs. now .
use common sense to make sure allen head is all the way in the screw head and do not overtorque .
i actually have the torque driver set , its sweet
Old 10-28-2009, 01:30 PM   #42
houston's Avatar
sorry noR , i was fibbin'
or not geez , some peoples kids
btw , got an email from someone lastnight
Old 10-28-2009, 01:34 PM   #43
CRAZYACE63's Avatar
Send a message via AIM to CRAZYACE63
Originally Posted by xlgraphicspro View Post
http://www.homedepot.com/Tools-Hardw...atalogId=10053
my wife bought me this ryobi, I thought it was alot more expensive than what it was, well it preforms like an expensive mini driver. Best thing is it has a clutch, and it's made for the ofna style hex bits. it's made wrenching on my car a breeze!
I have had this one for awhile now and put at least two kits and a few crawlers together with it. I wouldn't buy a $100 one if this was sitting next to it. The best thing for my hands. Especially since each wheel on my crawler has 32 screws to install.
www.ogrchobbies.com
SC8E
Tekin RX8
HB D8
Byrons Fuels
CRAZYACE63 is offline   Reply With Quote
Old 10-28-2009, 01:36 PM   #44
noR
noR's Avatar
Hey awesome. That's good news man.
I'll hold you to it. Everyone saw it happen.
I got those on houston's unending relentless arm-twisting recommendation. If it doesn't work out, I'll be sure to let 'em know.
I'd really rather get the MIP/Thorp; but funding always plays too-big a part in this decision making process.
Old 10-28-2009, 01:37 PM   #45
fatdaddy's Avatar
oh duh. i was thinking about my kit where i can use my bits in a drill or it has a handle adapter to make it a driver. yeah, you definately dont need a 1.5 for the drill, just a driver
as far as the 1.5 set screws, i can never tell what car is standard, metric, or both
Power Push Batteries ground-round Team and Company Discussions 745 06-18-2016 01:32 PM
Hex Drivers!(yes,another one) beginner4life Nitro Off-Road 12 10-27-2009 12:07 PM
Which Hex Drivers MaTt 93 Nitro Off-Road 15 10-26-2009 10:11 AM
Milwaukee 2.4v power driver with batt and charger... High quality driver. PIC INSIDE SCUBA STEVE R/C Items: For Sale/Trade 14 01-24-2008 08:42 AM
Novak Power Capacitor jonski Electric On-Road 29 12-18-2003 10:41 PM
