Old 10-26-2009, 02:47 PM   #1
Nitro F150's Avatar
Default How hard is it to tune a new engine
I just got my new engine for my nitro Rustler and im scared of ruining it. How can I learn how to tune it? I dont understand the clockwise stuff.
Nitro F150 is offline   Reply With Quote
Old 10-26-2009, 02:54 PM   #2
fatdaddy's Avatar
follow these two threads:
start with: http://www.rctech.net/forum/nitro-of...eak-bible.html
then go onto: http://www.rctech.net/forum/nitro-of...ing-bible.html
its not too hard if you stick to the instructions and use some common sense. just keep asking questions if you get stuck
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 10-26-2009, 02:59 PM   #3
shanty140's Avatar
Here are a couple threads that will help you out alot.
Bascially the way you tune the motor is through the needles. You turn them clockwise to lean the mixture and counter clockwise to richen's the mixture. Before you start tuning the motor for performance you are going to want to break it in. That thread above will show you how to do it.
Here is a video on how to tune a motor, the vehicle and motor are different but the principles are the same.
http://www.youtube.com/watch?v=ma2_C...eature=related
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 10-26-2009, 03:07 PM   #4
boost_9jr's Avatar
The most important thing when it comes to nitro engines is the break in process. There are tons of articles telling you how to properly break in a new engine. The best method is to follow the instructions that come with the engine / model. After the break-in process is over, you can start tuning for performance. With 2 needle carbs, ALWAYS START tuning with the high speed needle first, as it affects the whole power-band. Once you find a good point to where you are high in the RPM's with blue smoke, then start adjusting the low speed. You'll only probably need 1/8th of a turn. Here's a rule of thumb: Left hand turns = Richen fuel mixture. Right hand turns = Lean fuel mixture. That goes for both needles. Finally adjust the idle setting according to the manual. A 1 mm opening is usually the biggest you'll need for idle. All adjustments should be made in 1/8 turn increments. Another rule of thumb is to break in the engine with the same fuel you plan to use. A good 20% nitro, 16% oil content will do fine. If you follow the instructions, you'll be fine. Have fun,.....oh, go easy on the pull starter (if so equipped..LOL)
boost_9jr is offline   Reply With Quote
Jammin JPX 21 Plus ( new) nothin special Nitro Off-Road 310 10-14-2010 01:09 PM
OS 12TR vs. Big $$$ Engine almtx3 Nitro On-Road 18 09-25-2010 02:28 PM
Hard to tune losi 2.0rtr? Outtacontrol58 Nitro Off-Road 18 08-20-2009 08:46 PM
This V-spec is driving me insane. Jonro Nitro Off-Road 95 03-30-2009 02:35 PM
