Old 10-25-2009, 10:31 PM   #1
Cory Kerber's Avatar
Default Ouchless Return Bands Melting
Has anyone else noticed their ouchless hairbands melting off their carb when heating the engine up with a heat gun? I got tired of melting them off, so i made a guard out of thin cardboard to put in between the carb and block.
I guess it's just wierd how the bands melt so easily, at such a low temp. I'm not even pointing the gun at them!
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 10-26-2009, 08:49 AM   #2
Racecrafter's Avatar
Trader Rating: 25 (96%+)
GMK's "Carb O's" won't melt with heat or lose their tension from fuel exposure.
http://cgi.ebay.com/GMK-SUPPLY-CARB-...item3ca57dc42d
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-26-2009, 09:02 AM   #3
I apologize in advance, but here goes
Dedinitly not for hot heads. LOL
Mine did the same thing. Regular ol rubber bands are the trick, but they too will melt with the heat.
3DRCRACER is offline   Reply With Quote
Old 10-26-2009, 09:18 AM   #4
houston's Avatar
Trader Rating: 91 (100%+)
i dont melt them but i dont use the heat gun on high either
i use a simple hangar9 heatgun on low setting and heat slowly up to temp .
what kind of heat gun are you using ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-26-2009, 05:17 PM   #5
The Harbor Freight $10 special. I always use the high setting so maybe that's the problem. I'll have to try the low setting. It's just weird how easily they bust with the heat gun.
*TEAM TERRIBLES*
Old 10-26-2009, 05:34 PM   #6
houston's Avatar
dude! be careful with those harbor freight ones , they get really f'in hot , like 800° or something crazy . i would definitely suggest low setting and keepin the heat gun about 6" away .
monty
Old 10-26-2009, 05:48 PM   #7
monty
Thanks for the heads up. I've only used it a few times, so i will start using it on the low setting 6" away.
*TEAM TERRIBLES*
