Old 10-25-2009, 05:07 PM   #1
revo61's Avatar
Trader Rating: 18 (95%+)
Default Bearing problem
I thought my front bearing in my vspec had a leak. So took the flywheel off and found the shield was cut. Looks like washer I had on it before the cone and the flywheel cut into it. Anyone ever had this happen?
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 10-25-2009, 05:30 PM   #2
Zerodefect's Avatar
Pretty sure if your going to use a shim/washer behind the collet you have to use a clutch shim type that isn't a bigger diameter than the collet. Those are what I've allways used.
Oh well, bearings are cheap. And you get to tear down the Vspec to clean the "Vspec Conrod Gremlins" off.
Zerodefect is offline   Reply With Quote
Old 10-25-2009, 05:34 PM   #3
chunk t's Avatar
Washers are stamped and can end up with a bur or lip on one side if they are not sufficiently tumbled (de-burred). Personally I've always run the cowlet against the bearing without the use of a washer/spacer. I have seen bearing seals get chewed-up by a piece of sand/grit that got trapped behind the flywheel. Those lip seals aren't the most robust
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Engine tunning problem? jameslow Nitro Off-Road 9 05-04-2009 10:57 PM
rear bearing problem.... revo61 Nitro Off-Road 9 04-30-2009 12:06 PM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
bearing leak??? JRGTR Onroad Nitro Engine Zone 6 03-03-2008 04:04 PM
clutch bearing problems cwalters Electric Off-Road 39 09-11-2006 06:59 AM
Is this a clutch problem? albertlam Nitro On-Road 31 03-17-2003 08:18 AM
