Old 10-24-2009, 10:02 AM   #1
Nitro F150's Avatar
Default How to make Nitro Rustler faster with $120?
I have a new 2.5r engine in it.
Nitro F150 is offline   Reply With Quote
Old 10-24-2009, 11:23 AM   #2
pickle311's Avatar
Trader Rating: 31 (100%+)
Faster how? You do realize that speed is determined by gear ratios right? I don't care what motor you have, they all turn close to the same RPMs which means you aren't going to see much difference in top speed between motors. What you will see is a difference in how fast it reaches the top speed. If all you're wanting is more top end, go up 1 or 2 teeth on your clutch bell. Keep in mind that you will sacrifice bottom end to gain top.
I guess the real question I should ask is what are you doing and what is your goal? Are you wanting to turn faster laps at the track, or do you want to blaze up and down the road in front of your house faster?
pickle311 is offline   Reply With Quote
Old 10-25-2009, 06:04 PM   #3
JP2 or JP3 pipe, digital servos, aluminum clutch shoes, higher nitro content, changing teeth on clutch bell all help in making i faster.
Trivium04 is offline   Reply With Quote
Old 10-27-2009, 10:02 AM   #4
How and why would you put a jp2 jp3 pipe on a small block engine?How are aluminum clutch shoes and digital servos going to increase top speed?
BeefHead is offline   Reply With Quote
Old 10-27-2009, 10:27 AM   #5
I would not spend $120 on a Nitro Rustler. There is nothing you can do with that money that will give you NOTICALBE speed.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 10-27-2009, 10:50 AM   #6
xnitrorc's Avatar
Send a message via Skype™ to xnitrorc
Smile Has a Point
There shiny and look cool
Have you got the X in X Nitro RC?
http://www.xnitrorc.co.uk
Schumacher Racing - http://www.xnitrorc.co.uk/~xnitrorc/127-schumacher
xnitrorc is offline   Reply With Quote
Old 10-27-2009, 11:18 AM   #7
scwrod's Avatar
Here is one way and it is only $26.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 11-06-2009, 06:09 AM   #8
xnitrorc's Avatar
Have to try that!
