Old 10-24-2009, 03:47 AM   #1
Shem's Avatar
Default Ackerman/Steering/Upperarms
Hello.
Can someone please help me with setup for the mbx6.
Ackerman settings:
I like the car to stear tieght and strong. At the moment i am having trouble 50% out the corner, nose is going to much outwards.
And:
Front Upperarms/Anti Squat:
Position of the upperarms... Move them to the front helps? Or to the back.? I feal very much steering moving them to the front, but this should be wrong for bumpy track.?
So any recommendation are more than welcome, total setup for bumpy tracks, that i can try out maybe. Really need a perfect setup for season 2010, to many problems this year.
At the moment i am running front 10.000/7000/7000 in diff's
Regards
Shem is offline   Reply With Quote
Old 10-24-2009, 06:44 AM   #2
Send a message via MSN to Adim_X
I am sure you will get more responses in the Mugen MBX6 thread. There is a lot of knowledge there.
Privateer:
Mugen MBX7R ECO/Nitro, Hitec, Sanwa, Jconcepts Tires, OS Speed, Bones Fuel, Fantom
Adim_X is online now   Reply With Quote
Old 10-24-2009, 07:33 AM   #3
Shem's Avatar
Sorry, but where is this thread?
Old 10-24-2009, 09:19 AM   #4
Mugen MBX6
This is the last page right now.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 10-24-2009, 10:30 PM   #5
Lille-bror's Avatar
Hi Shem.
Nothing beats practical experience, but if you want to learn the theory behind the set up, you should read HUDY Off-road & Truggy Set-up Book:
www.teamxray.com/teamxray/showfile.php?file_id=4461
See you at races in 2010?
Cheers
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 10-25-2009, 12:30 AM   #6
Shem's Avatar
Originally Posted by Lille-bror View Post
Hi Shem.
Cheers
Niiiice thank you LilleBror... See you at the track.
Mugen mbx6, Ninja JX
Mugen mbx6t, Ninja JX
Futaba 4PK
Old 10-25-2009, 08:29 PM   #7
j_blaze14's Avatar
Trader Rating: 34 (100%+)
10/7/7 in a buggy? bumpy track? read the hudy guide.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 10-25-2009, 08:38 PM   #8
Zerodefect's Avatar
Understeer problems?
Drop to 7/5/3 diffs or 5/5/5
Increase rear camber to -3 or greater.
Akerman to the rear unless your on a real big track.
Use the optional underdrive gear on the rear diff. That way the front spins faster in the front giving more on power steering and dragging the rears off power giving more turn in. (In some areas this can also cause more understeer, sometimes it works.......)
Zerodefect is offline   Reply With Quote
Old 10-27-2009, 05:26 AM   #9
Shem's Avatar
Thank you very much....
Futaba 4PK
Old 10-29-2009, 10:23 PM   #10
merdith6's Avatar
Default try this....
I tuned a few, and the first thing is to move the upper arms to the front all the way, put 40 wt oil all the way around, maybe 45 in the front, put 5-7-3 in the diffs, and put one thinner front swaybar on the front. the shock travel is really long so putting spacers in the shocks to limit it just a little, maybe 2mm f and rear, then tires, depending on the track I like aka tires best right now they last forever too. Go ove the pivot balls relly well, there may be a binding problem you haven't seen, and mostly check the toe in out. I like perfectly strait myself and play around with the end point adjustments, and try a larger aluminum servo horn, adjust brakes more to the rear, and lighten up on the front brakes. Try not to limit the ride height in the front it can drive weird too low. I hope this helps.....
merdith6 is offline   Reply With Quote
