Old 10-23-2009, 03:30 PM   #1
Default Clutch Bearings ???
Hello,
I am kinda new to buggy's and just found this forum and thought it would be a good place to ask.
I have a Mugen MBX5 with a VZB in it. I would like to know what you guys have found to be the best clutch bearings to use that last the longest between service??
Also, what are the most comon were items that I should keep on hand for spare parts? I only have the one buggy so I would like it not to be down for long time (:
Thanks, and a great forum to!
Kevin.
Kevin.R is offline   Reply With Quote
Old 10-23-2009, 03:35 PM   #2
fatdaddy's Avatar
i always reccomend TKO brearings. after i got a pair from Peter a couple of races ago i will be using these from now on. i was super impressed. over a gallon on the same clutch bearings and they are still silky smooth
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 10-23-2009, 04:05 PM   #3
I would recommend Avid bearings they are only a dollar each for any size and they last as long as anything else.
As for parts I would recommend at the least keeping an extra set of all your arms.
matrixmike28 is offline   Reply With Quote
Old 10-23-2009, 04:12 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
Personally I like the Losi HD bearings. I pull them and clean them and they have lasted at least a gallon before I think about changing them.
Old 10-23-2009, 10:15 PM   #5
tc5 man's Avatar
tko ceramic bearing for the clutch and defiely the high rpm bearing they have it says smooth and last for a while
Old 10-23-2009, 10:32 PM   #6
Hey man if your bashing just buy the packs of cheap ones and run em till they get gritty.If your racing just buy the packs of cheap ones an replace after a full race day.If your running carbon shoes your bearings will last much longer.If your running aluminum shoes they will not last as long.A busted clutch bearing will mess up your race day and its not worth it to try and get much more than a day or two out of racing out of clutch bearings.You have a mbx5 with 5x10 bearings wich will not last that long regardless of the make.DONT waste your money on high $ clutch bearings its not worth it.
BeefHead is offline   Reply With Quote
Old 10-23-2009, 10:56 PM   #7
tc5 man's Avatar
the best ones that i ran that are cheap are the tko grated i do race though not a basher, i do run carbon and alum dont know how they would hold up running all alum but if u have enough play shouldnt a alum setup last longer than a full race day,u have a mugen truggy come out and race that thing
Old 10-23-2009, 11:02 PM   #8
tc5 man's Avatar
oh duh he has a buggy not the truggy,
Old 10-23-2009, 11:03 PM   #9
Aluminum shoes run much hotter.All that heat in the clutch bell melts and burns off the grease/oil out of the bearings much faster than with carbon shoes.But in a truggy i would prefer to run alum because they grab harder.
Old 10-23-2009, 11:15 PM   #10
tc5 man's Avatar
oh ok how does the alum/carb run on a truggy ,the thing is with the 2 alum/carbon ,for the carbon to last u have not have it at a stiff spring setup cause they wont last. my is a gold/green setup on my losi clutch and its smooth with still haveing plently of punch. so most buggy guys dont do all alum shoes
Old 10-23-2009, 11:45 PM   #11
houston's Avatar
Trader Rating: 91 (100%+)
TKO special clutch bearings are badass , I have never had come apart. . The avid bearings used to be my choice until they just started exploding .
Once again TKO special 5x10mm clutchbell bearings. Www.tkocompetitiondev.com
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-24-2009, 12:09 AM   #12
tc5 man's Avatar
1 on the tko bearings why do they say have the blue sheid facing the front and the black seal inside,i been running the black seal facing the front and its fine is there a better proformance if u have the blue side faceing the front
Old 10-24-2009, 09:15 AM   #13
I have no idea why they are inserted a certian way,maybe seal integrity or offset balls like some of his rear motor bearings.
The way I read the noe on his site says blue seals face each other so at least one of your bearings(front) is facing the recomended direction.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 10-24-2009, 09:16 AM   #14
Trader Rating: 48 (100%+)
+1 on the TKO specials...
Up in the air...
Cyberacer is offline   Reply With Quote
Old 10-24-2009, 10:31 AM   #15
Integra's Avatar
I had a Tko 5x10 let go on me a couple weekends ago....and it was Brand new.
i have had great luck with then in the past tho.
What Clutch Bearings Do You Use? Frank L Nitro Off-Road 60 07-22-2009 02:43 PM
clutch bearings losi_racer Nitro Off-Road 33 11-17-2008 04:45 PM
Losi 8 buggy front clutch bearings???? btracing Nitro Off-Road 23 05-25-2008 12:42 PM
Clutch bearings for 8T crazyjr Nitro Off-Road 7 11-27-2007 07:58 PM
problems with clutch bearings on 8t rhymster Nitro Off-Road 13 09-10-2007 04:25 PM
