Old 10-24-2009, 02:22 PM   #16
gdux's Avatar
Originally Posted by houston View Post
TKO special clutch bearings are badass , I have never had come apart. . The avid bearings used to be my choice until they just started exploding .
Once again TKO special 5x10mm clutchbell bearings. Www.tkocompetitiondev.com
No Doubt about the TKO Special CB's. We pull them out every 2 weeks or so to clean and lube and they're buttery smooth waay past a gallon, for us...... Never seen anything like them. 2 alum 2 carbon on a losi clutch...
Gary Duxbury:
MUGEN SEIKI RACING / NOVAROSSI USA / AKA / M2C RACING / TKO / LUCKY 7 RC / VP RACING FUELS / PTRC RACING OILS /
PAINTMONSTER AIRBRUSHING.COM / UPGRADE RC
gdux is offline   Reply With Quote
Old 10-24-2009, 02:41 PM   #17
houston's Avatar
Trader Rating: 91 (100%+)
plus peter is really f'in cool . enjoyed his company at the nitro cross
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-24-2009, 07:28 PM   #18
Peter Martin's Avatar
Thanks Guys. If you ever have a problem with any of our products PLEASE contact me.
The "special clutch bearings" are directional. Blue seals face each other. This is for the thrust forces. They have steel balls and have a higher RPM rating then standard bearings.
peter.tko@gmail.com
909-256-4064
Thanks Monty....great seeing you too.
Peter Martin is offline   Reply With Quote
Old 10-24-2009, 07:45 PM   #19
Integra's Avatar
peter.tko@gmail.com
909-256-4064
question Peter....Is it possible to get a bad bearing in a batch or no ?.....ive normally had really good luck with the 5x10 and 5x13 in the losi clutch but like i said earlier i had a BN 5x10 take a dump with basically the A-main warm up...and it failed big time....balls and races all over the place.
curious more then anything......thx
Old 10-24-2009, 09:58 PM   #20
Was it a special ? Yes all bearings are hand assembled. Things do happen. We always check what we can especially if we see an early failure. Fortunatley we do not have to do it often.
Old 10-24-2009, 10:04 PM   #21
Peter is great guy. I never have meet him but buy bearings from him.
bigde2001 is offline   Reply With Quote
Old 10-25-2009, 07:31 AM   #22
Integra's Avatar
ya it was a Fancy one.....Hand assembled...Wow didn't know that....Very interesting.
Old 10-25-2009, 10:52 AM   #23
Frank L's Avatar
Trader Rating: 148 (100%+)
Man I had that same thing happen to te 5x10 tko special bearing it caused 2 flameouts and that equaled 5th place in the a main. Went back to the losi HD and no issues. TKO engine bearings are all I use though.
What Clutch Bearings Do You Use? Frank L Nitro Off-Road 60 07-22-2009 02:43 PM
clutch bearings losi_racer Nitro Off-Road 33 11-17-2008 04:45 PM
Losi 8 buggy front clutch bearings???? btracing Nitro Off-Road 23 05-25-2008 12:42 PM
Clutch bearings for 8T crazyjr Nitro Off-Road 7 11-27-2007 07:58 PM
problems with clutch bearings on 8t rhymster Nitro Off-Road 13 09-10-2007 04:25 PM
