Old 10-22-2009, 02:12 PM   #1
Default rb s3 rod in a nova n21bf limited ???
Hi I have a new rb s3 conrod and wanted to know if it will work in my nova n21bf limited? thanks.
rustyrevo is offline   Reply With Quote
Old 10-22-2009, 02:54 PM   #2
22Racer's Avatar
Trader Rating: 67 (100%+)
Rb's use a slightly bigger crank pin dia. so it would be a little loose on the Nova.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 10-22-2009, 03:04 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
I don't think so but I could be wrong.
Nova rod lesson:
Nearly all Nova based .21 motors (including RB S, C and WS motors) use the R series rod, R1 through R7. They all have the same dimensions, higher numbers are just improved versions.
The exceptions:
1. I believe short stroke motors use a different rod and I believe the BF21 is one of those, not sure though as I have never had one of their short stroke versions.
2. Smaller crank pin motors. These are mainly onroad motors though I think they did try this on one of the high end offroad motors too. This would be the Collari edition and Cordoba motors (4.5mm crank pin) that use C series rods and the 353 (4mm crank pin) that uses a P series rod. These are the same length as the R rods, they just have a smaller lower rod bushing for the smaller crank pins.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-22-2009, 05:30 PM   #4
Davidka's Avatar
Trader Rating: 75 (100%+)
Up until 2 years ago, RB engines had different crank pin sizes than most all others. I think it was smaller to reduce bearing surface speed. I don't know whether or not they changed, 2 years ago was the last time I heard it mentioned.
Old 10-22-2009, 06:20 PM   #5
Send a message via Yahoo to phoenix357
bf 21 uses a r7
phoenix357 is offline   Reply With Quote
Old 10-22-2009, 06:57 PM   #6
wingracer's Avatar
Originally Posted by phoenix357 View Post
bf 21 uses a r7
If that's true, an RB S whatever rod should work just fine. I would break out the calipers and check it first just to be sure though.
Team Shepherd USA
