Old 10-22-2009, 06:56 PM   #16
rotarynut's Avatar
Trader Rating: 30 (100%+)
Default balancing tires
Just for what it's worth, in the automotive trade there's a process called "MATCH BALANCING" meaning you find the heavy spot on the wheel, then you mount the tire and spin it on the wheel until you get sometimes a perfect match (no weights used) or keep weight to a minimum (no big chunk of lead on your wheel) in the case of buggy's and truggy's you may also move the foam around, I don't know if it's feasible. If somebody has a balancer and some new tires give it a try, it just might be something to put in your bag of tricks
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 10-22-2009, 08:27 PM   #17
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
there is an exellent tire gluer for buggyz made by russ weidmont designs....it is dialed....i am told it is what aka uses to mount their tires....i have one and it the best thing i have ever bought
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 10-22-2009, 08:48 PM   #18
Integra's Avatar
Originally Posted by Michael#81 View Post
I would get this balancer over the prop balancer. With the prop balancer you have to buy an extra adapter to use it with the 1/8 scale wheels. In the long run this one is cheaper and I think it gives the wheel a more true roll.
http://www.amainhobbies.com/product_...-Tire-Balancer
Ive Tried Both Dyna and the Hudy balancer's and feel they are No where NEAR as accurate as the Dubro prop balancer...as far as an adapter...you need a spare 17mm hex and Nut and a couple pieces of fuel tubing...No adapter needed.
If you want to get REAL anal about balancing try doing your rims with a Magnetic prob balancer...there nice item's to have in the shop when balancing tires.
ALSO MAKE sure to Spin up the tires for at least a quali or 2 before balancing...the foam's WILL shift and cause the balance to be out once they find their seat.
ALL TIRES require balancing Buggy or truggy....they May Not shake or wobble on the car...but on the balancer They ARE out....whether it be .5g or 1g....Ive Never come across a set that was 1000% purfect out of the package or after glueing.
Old 10-22-2009, 08:48 PM   #19
Integra's Avatar
linky ?
Old 10-22-2009, 09:14 PM   #20
Trey7's Avatar
Good video to watch for those new to balancing.
http://www.youtube.com/watch?v=eo8uq...rom=PL&index=6
Hobby Pro USA, Beta Tires, VP-PRO-USA, Werks Racing, Team Associated, Savox
Trey7 is offline   Reply With Quote
Old 10-23-2009, 12:08 AM   #21
Beddo's Avatar
Just to clarify then (sorry, real n00b here) you mount and glue the tyres (UK spelling ) run them for 1/2 and hour or so, then balance them?
Thanks in advance.
Beddo is offline   Reply With Quote
Old 10-23-2009, 06:43 AM   #22
Integra's Avatar
Thanks in advance.
yes run them prior to balancing...but not 1/2 hour....a quali or 2.....unless you run 15 min quali's... Just jokes buddy.
Squirrel's method is WRONG DO NOT folllow his balancing advice on his vid...it may seem right but i tell you its wrong on many level's.
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
Mounting Tyres RAST Australian Racing 9 03-28-2007 06:06 PM
Cutting Down Foam Tyres Oasis2001 Australian Racing 18 10-06-2004 09:51 AM
26mm tyres on 24mm wheels trf racer Electric On-Road 8 11-11-2003 01:14 AM
