Old 10-21-2009, 07:13 PM   #1
Suspended
Trader Rating: 4 (83%+)
Default Carb reducer help.
Hey guys I have an OS V spec. I also have the red (7mm) reducer and the Blue (8mm) reducer. What are the different affects of each? And how do I know which to use?
LosiDriver4Life is offline   Reply With Quote
Old 10-21-2009, 07:28 PM   #2
They just alter the fuel:air ratio, makes for less air to the mixture. The motor becomes a lot more drivable and the fuel economy improves, the smaller the insert.
I don't personally run a V-Spec, but I have heard of a lot of people running the 6 and 6.5MM reducer and getting really good runtimes.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 10-21-2009, 07:28 PM   #3
jrwoodchuck's Avatar
If you have the restrictors that come with the engine, the blue is 9mm and red is 8mm. the smaller the restictor, the less power you have. It can make the car easer to drive plus give better fuel milage. but, a smaller restictor can be harder to tune. but 8mm is easy to tune, it's when you get down to 6mm that if youre not experenced with tunning, can be difficult.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 10-21-2009, 07:53 PM   #4
Suspended
Ok thanks. So what should i do before switching to a smaller restrictor? Should i richen up the engine and retune?
Old 10-21-2009, 08:00 PM   #5
I wondered the same before I dropped down from 9 to 7mm. I was told by several people to just drop it in and see how it is. You may need to lean a bit.
A smaller restricter is just less air. You still have the same fuel values, so you may have to lean to optimize the mixture for the reduced amount of air. This is where the decrease in power and increase in economy and drivability comes in.
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
For Sale OS 28XZ 8secnotch R/C Items: For Sale/Trade 9 07-25-2009 10:29 AM
ninja jx .21 help plz downunder23 Nitro Off-Road 20 02-19-2009 01:00 AM
First impressions of my 3 port Go-Tech. (non R spec) Furadi Nitro Off-Road 20 04-03-2008 10:17 PM
