Old 10-21-2009, 10:48 AM   #1
Default return spring
Thinking of a good return spring setup for the throttle in case of a servo failure. I seen the rubber band, and spring trick, but if someone has other ideas, please share them. Thanks!
inpuressa is offline   Reply With Quote
Old 10-21-2009, 01:28 PM   #2
AndrewClaycomb's Avatar
My LHS carries actual return springs. They don't create very much tension, just enough to get the job done and they are cheap. Not as cheap as a hair tie or a rubber band, but probably as cheap as a pack of rubber bands or a pack of hair ties.
Tekno 8ight
Kyosho Ultima SC
AndrewClaycomb is offline   Reply With Quote
Old 10-21-2009, 02:54 PM   #3
t4usee's Avatar
go to your local walmart store and purchase the "ouchless" hair bands made by goody. they are more than strong enough to return the throttle and hold up for ever to the heat and fuel that gets on them. it's not a rubber band so dont get confused!
t4usee is offline   Reply With Quote
Old 10-21-2009, 02:56 PM   #4
Razathorn's Avatar
I just went to the hardware store and grabbed a few easy to pull springs from their spring drawer and cut/bent them to hook to a hole on the side of my chassis and on my servo horn. I then cut it to length so it just over powered my servo when the power was turned off. Works great.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-21-2009, 09:48 PM   #5
fast11970's Avatar
I like the Sh Return Spings, But thanks For the "Ouchless" Tip, Springs do no always fit , and Regular Rubber..Melts.
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 10-22-2009, 03:23 AM   #6
MaTt 93's Avatar
Send a message via MSN to MaTt 93
I use the rubber bands that i have to put on my braces
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Best throttle return spring? bmxRRT Nitro Off-Road 6 04-22-2009 11:32 PM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
