WHAT PIPE FOR A NINJA JX
As cjm said the 2042/2060 is the best, but if your running the mugen car you should deff run the mbx6-80 header.. not only does it make the best power but it also fits the best with the tight bend..
I use the RE-11 on mine and love it, in fact I went up one tooth on my pinion to make it more controlable in my buggy.
+1 on the 2060/ 2042. They are the same pipe. Joe (jpalessi) hooked me up with a 2042 pipe and L shaped header to run on a speed engine in a truggy and it works the best. I have a 2060/ speed in the buggy and the thing pulls hard no matter what rpm. You can mess with the losi pipes but theres nothing like the original.
losi re10 i run it great pipe smooth and fast for half the price of the os pipes
If you can find one try the EB MODS pipe. I have one on both of my Ninjas in my 6 and 6T. Great power.
JP-6 + PTM ninja 6mm venturi = more than enough power and 12+minute runtime
and jammin coated pispes are so easy to clean.
need to try JP-4 next year.
Those where between my v-spec and speed
