Old 10-23-2009, 11:16 AM   #16
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
So to also get this right I would take the high needle down till snug then come back up 3.5 turns correct.
kodiakbear7070 is offline   Reply With Quote
Old 10-23-2009, 11:17 AM   #17
Yes it is fuel is Byron 30% / 11%
Originally Posted by matrixmike28 View Post
What fuel are you using? Axe motors are not shimmed for 30% from the factory. I learned that the hard way. If you are running 30% you must add .02mm of shimming. Your low end seems to be way to far out aswell. That is a mamba x1 evolution right?
Old 10-24-2009, 02:38 AM   #18
It is an Axe Rossi Mamba x1
Originally Posted by midwestcajun View Post
I might be wrong but it really sounds like you are super lean on the low end, not sure about high end because you havent told us how it is once you get rolling. Its straining for fuel hence the high idle. You might want to see if you can find the factory needle settings and start over. That has worked for me in the past when someone decided they should start cranking the screws on my mill and I had no idea what they did.which I have learned I will never allow to happen again. BTW...250 isnt bad depending on what engine you have which we still dont know. Tune to performance....good smoke and response and you should be fine. Engine temps vary considerably depending on what kind. Reedy's only run solid around 260-270 which would freak temp tuners out but others are around 220...my Dynamite is right at the 220 mark and thats not a "race" tune. If it feels right and blows smoke then run it.
