Idling problem.
Idling problem.
Ok guys I have a question. I first started tuning my engine by setting the idle. Then i started tuning the low speed and high speed needles. I got those set. So is it possible since I leaned out the high speed and low speed, the idle is now too high? Because it like to start reving as soon as i start the engine and the wheels also start spinning. I was thinking its an air leak but would like to know if this can happen. Thanks ahead of time
If you lean the low end your idle will come up. As you lean the bottom end you need to lower the idle to compensate.
Okay thank you.
