Old 10-17-2009, 02:47 PM   #1
mudboger07's Avatar
Default Tunning help please
The car: losi 2.0 8ight buggy, stock motor with turbo head(3 shims), re11 pipe, byron gen 2 30% everything else stock. P3 turbo plug
The problem: at idle it runs great, but when doing a high speed pass it seems to fall off like its runing out of fuel. I had it tuned great when the weather was around 70 degrees but with engine temps at 230 to 250, today i was running i t to get ready for some practice at the track tomarrow and no matter what I did i couldnt get it to run over 200, out side temps today are 50 degrees, leaning it out seemed to bring the temps up but made it fall off at high speed, riching it up seemed to make it run better but also brought the temos down. should I use a P6 plug or? Thanks for any advice......
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 10-17-2009, 03:28 PM   #2
Zerodefect's Avatar
High needles too lean
Low needles too rich.
out of balence settings probally. the low end is keeping temps in check but as soon as you get up to speed she lean bogs right?
reset idle screw after adjusting.
Zerodefect is offline   Reply With Quote
Old 10-17-2009, 03:51 PM   #3
hyperc10's Avatar
Send a message via Yahoo to hyperc10
High speed too lean and the plug is fine richen top two hours & lean the low two hours this should bring your temps up and also your idle, just readjust idle after you run a couple of laps or your up too running temp.
hyperc10 is offline   Reply With Quote
Old 10-17-2009, 04:21 PM   #4
mudboger07's Avatar
thanks guys, that sounds liekit will work, I'll give it a shot in the morning.....it's deff a lean bog at high speed, I'll start with riching up the high side 2 hours and leaning the low side 2 hours and go from there.....what would happen if i switched to a p6 plug btw.
Ken
Old 10-17-2009, 04:30 PM   #5
Zerodefect's Avatar
I have never gone colder than p4 with OS plugs.
A hott OS P3 plug is really easy to tune and good for short tracks, but it can advance your ignition too much and steal some of your top end. P5 may give you better top end.
Old 10-17-2009, 04:38 PM   #6
mudboger07's Avatar
Ive got a p3 in it now and a p6 to try, i was thinking with the cold a p6 might work better im not sure, i prob should stay with the p3 ya? oops i just read how to tell what the temps are for plugs and saw that the p3 is ultra hot and the p6 is cold....So i guuess ill stay with the p3......
Ken
Old 10-17-2009, 05:23 PM   #7
hyperc10's Avatar
I would stick to the p3 it runs hotter P6 is a medium plug it's getting cooler out and the air is more dense.You will find that these engines love this weather!! That's probally why your running lean on top more Oxygen.
Old 10-18-2009, 07:01 PM   #8
mudboger07's Avatar
Well that was it zero, I made the changes to the high and low needles and wow what a difference......this thing screams now.......
Ken
Old 10-18-2009, 07:44 PM   #9
madweazl's Avatar
Out of curiosity, what elevation are you running? I'm having to run 6 shims (.6mm total), are you running 2 .2mm and 1 .1mm or 3 .2mm?
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 10-19-2009, 01:18 PM   #10
DuckAxe's Avatar
That thing definately looked good yesterday. It was pulling with my OS Speed. I liked it so much I went and bought one today.
We are about 300 ft ASL. Tennessee
DuckAxe is offline   Reply With Quote
Old 10-19-2009, 02:04 PM   #11
DuckAxe's Avatar
Ken, What brand turbo head will work?
Old 10-19-2009, 03:14 PM   #12
mudboger07's Avatar
Here is the link, I bought it from losi....i think the price was around $20
and came with 3 shims and a t3 turbo plug..the head and the re11 really woke this thing up.......
http://www.horizonhobby.com/Products...prodDetailTabs
Ken
Old 10-19-2009, 05:14 PM   #13
mudboger07's Avatar
hey mad, I'm running the 3 that came with the turbo head and an extra one i'd bought that was 1mm, I'm not sure the thickness but the next time i pul the head I'll measure it.
Ken
Old 10-19-2009, 05:19 PM   #14
mudboger07's Avatar
Thanks hyper, i put the p3 back in and it tuned very well....
Ken
Old 11-01-2009, 05:48 PM   #15
xBRxSAIGON's Avatar
I had the same prob.
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
having trouble tunning my savage x 4.6 help needed esp6606 Monster Trucks 13 04-15-2009 06:39 PM
os VSPEC will not IDLE/tune, please help patrick21x Nitro Off-Road 26 08-04-2008 12:20 AM
I need advise on pinch test/tunning... Mpowerz Nitro Off-Road 28 01-16-2008 12:36 PM
