Old 10-17-2009, 01:50 PM   #1
Default Hetic Servo HS-7955TG HELP
I am installing two new servoes in a RC8t. Under no load both servos have a humm and a little vibration. The the sterring one more than the throttle. Is there something I need to adjust?
bguad
bguad is offline   Reply With Quote
Old 10-17-2009, 02:00 PM   #2
Normal.They have very high resolution & are trying to center but the slop in linkage is bouncing back & forth.If you hold a little pressure on the servo arms & the buzz stops then this is your problem. Well not exactly a problem but the cause.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 10-17-2009, 02:12 PM   #3
I gave that a try and they still are vibrating. It has been a long time since I did this, but just seems that they shouldnt be making noises and vibrating.
Old 10-17-2009, 02:30 PM   #4
Zerodefect's Avatar
Usually normal. They buzz because they are constantly trying to center.
Usually you can bounce the car and they might find a spot with no load. The weight of your linkages is pulling on them.
If you remove the servo linkage. No arm, nothing. They should be quite with maybe a few clicks. Some clicks but not much.
If they are really noisey with nothing attached, its your radio.
Zerodefect is offline   Reply With Quote
Old 10-17-2009, 04:50 PM   #5
Trader Rating: 21 (96%+)
i have that servo .......its normal
john stu is offline   Reply With Quote
Old 10-18-2009, 10:23 AM   #6
wfo
wfo's Avatar
+1 NORMAL just the slightest tension will cause the humm/buzz noise its just a hight oz. servo trying to center ..
wfo is offline   Reply With Quote
Old 10-18-2009, 10:39 AM   #7
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
they are digital.........that's why they hum/jitter.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is online now   Reply With Quote
