Old 10-17-2009, 09:22 AM   #1
Suspended
Trader Rating: 4 (83%+)
Default Could it be an airleak?
I was having trouble with my engine yesterday. I started the car and it idled fine. Then after 30 seconds it would start to idle extremely high and the wheels would start moving. I put the truggy on the dirt and it moved by itself. But it cant be the idle because i turned it down and it still did it. And the carb wasnt opening either. Its an V Spec with 3 gallons on it. Not sure what could be wrong. Any suggestions?
LosiDriver4Life is offline   Reply With Quote
Old 10-17-2009, 09:45 AM   #2
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
sounds like an air leak or possibly to lean on the bottom end
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 10-17-2009, 09:59 AM   #3
Suspended
So should i seal it up?
Old 10-17-2009, 10:04 AM   #4
Send a message via Yahoo to tominator06
You could try sealing it up. It may be the front bearing. They can develop air leaks after some time. May also want to check the o-rings in the hsn. Good luck.
tominator06 is offline   Reply With Quote
Old 10-17-2009, 10:12 AM   #5
Suspended
How could i find out if its the front bearing? And i would need to replace that right.
Old 10-17-2009, 10:50 AM   #6
Not sure how to test it but if you have ever noticed any oil residue on the front bearing or in the clutch assembly. Thats how I noticed it on my nova. I actually just got my new front bearing fro avid this morning. I guess I will tear down a couple motors today and replace the two front bearings. I got a ceramic for the nova and the bearing rbmods gave me for the xtm 457. The standard bearing is like $5 and the ceramic one I got for the nova was $10 from avid rc. I would just replace it for 5 bucks if your motor has some time on it. That way you will be sure. My nova would high idle after wot runs. I first thought about idle gap and a fat low end but after trial and error and much tuning I am pretty sure its the front bearing. I had the motor sitting on the bench for a few days without a clutch on it and noticed a little oil droplet on the bottom of the front bearing. Bam that reminded me of what Rick from rb mods said about my xtm 457 having the same problem. I hope you figure it out.
Old 10-17-2009, 06:30 PM   #7
Got a little Captain in ya??
Gilley11's Avatar
Trader Rating: 15 (100%+)
If you plug the exhaust and fuel inlet port,you can blow into the carb with the engine held upright. Put a couple of drops of fuel on the bearing and you'll see it bubble up if it's a leaking. Kinda shadetree but it works
Gilley11 is offline   Reply With Quote
Old 10-17-2009, 07:02 PM   #8
Guest
Send a message via Yahoo to T4-RC8 RACER77
Default motor
i seen the same thing last week, i changed out the 2 orings 1 on the carb and other in the motor. the lower carb oring that in the carb hole, and i changed out the front bearing.
T4-RC8 RACER77 is offline   Reply With Quote
Old 10-17-2009, 07:29 PM   #9
Just put a new ceramic front bearing in my nova/rex p5x this evening. Took a quick pic with my phone. Its a little out of focus. The crank has rbmods signature on it and an R engraved on the con rod. Looks like quit a bit of grinding was done to the crank and sleeve. I hope the rain stops so I can burn some nitro thru it tomorrow. I also hope the bearing takes care of the suspected air leak.
Hobao GPX4 Pro chrisman Nitro On-Road 781 05-06-2013 07:47 PM
Carb - Impossible tune. Orangetang Nitro Off-Road 22 06-19-2009 09:19 AM
Nitro newbie with an embarrasing question Imperator Nitro Off-Road 41 10-20-2007 08:58 AM
Airleak? augerpro Electric Off-Road 14 10-19-2005 05:50 AM
some problems with savage classic xl Monster Trucks 21 07-16-2005 04:05 PM
Inconsistant Spray Problem Driving Me Nuts Griffin Painting, Designs, Graphics and Photography 12 05-11-2004 10:27 PM
