Old 10-15-2009, 02:37 AM   #1
Default What About 4Stroke!
Just wanted to see other peoples thought about this.If it ever happens what would mean for our hobby/sport?I think it would be cool.With todays cars being lighter the weight would not be a problem and the slightly lower power output.Lets hear what you guys think.
BeefHead is offline   Reply With Quote
Old 10-15-2009, 04:27 AM   #2
4-Stroke? Why? The cost to make it would make it out and out crazy. I'm not buying a 1,000$ mill just to say I have one.
The Working Man is offline   Reply With Quote
Old 10-15-2009, 05:39 AM   #3
what would be the point?
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 10-15-2009, 06:42 AM   #4
Zerodefect's Avatar
Why would weight be a problem? A Saito .54 weighs about the same as a OS .28 xz last time I checked.
Have you seen one? Awesome performance in a truggy. A little less top end. Improved torque, throttle response, tune, less wheel spin.
Zerodefect is offline   Reply With Quote
Old 10-15-2009, 07:01 AM   #5
Less noise smoother power band better run time longer engine life easer to tune holds tune better and sounds cooler.Dont you run 500$ os speed.
Old 10-15-2009, 07:13 AM   #6
It would not cost 1000$.Only if it were os would it cost that much.We are getting screwed by engine manufactures any way you look at it.
Old 10-15-2009, 07:34 AM   #7
Lonestar's Avatar
actually, OS did if for Kyosho a few years back on a Superten (kinda scaled up 10th scale onroad)... it was expensive, but defo not priced out of the market.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-15-2009, 07:37 AM   #8
SQC049's Avatar
Trader Rating: 16 (100%+)
Someone has a 4 stroke conversion out for the GT2 now. I would love to see one for 8th scale buggy, would be pretty cool I think.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 10-15-2009, 07:41 AM   #9
Yes i have seen the os engine you speak of.But i would not say that was a ground up design.We need a 4stroke engine designed for 1/8 scale specificly.
Old 10-15-2009, 07:46 AM   #10
rider313's Avatar
Trader Rating: 94 (100%+)
4 stroke engine dont make as much power per cc as a 2 stroke. so if you took a .21 four stroke agenst a .21 two stoke the two stroke would dominate. bringing in the four stroke would have to mean that they would need to make a handicap size just so the four troke can keep up. I just dont se RC racing going in this direcion..
rider313 is offline   Reply With Quote
Old 10-15-2009, 07:55 AM   #11
As i said the cars are getting very light.Every one is going for runtime now and as a result the engines are making less power.Yes 4stroke make less power.Every one knows that.But with todays teck.i think they would be very good.Our cars are over powerd as is.Ever watch motor cross.
Old 10-15-2009, 07:56 AM   #12
Zerodefect's Avatar
Yes, we would have to run around .48-.51 size engines.
If the clubs allow electric in with nitro, I don't see why they wouldn't allow bidg 4-strokes or .28 2's in buggies.
If the rules are open enough to run electric or nitro together, their open enough for nearly any powerplant.
Some have run 4 stroke airplane engines in their truggies. It worked well enough. A 4 stroke specially desighned for cars would be way better.
I don't expect any engine companys to have the balls to produce one any time soon.
They'd make one, and all the Momos would blow it up quickly. They'd get a bad rap and all that R&D $$$ would be wasted. From a manufacturer stand point, it deosn't look like a safe bet to produce.
Old 10-15-2009, 07:57 AM   #13
I used to run karts and you had the option of 2-stroke vs 4-stroke. the 2 stroke motors were lighter, faster and cheaper. The 4 strokes used a whole lot more fuel too. It would be tough to set up rules to keep parity. the 4 stroke would need to be bigger in size and have bigger fuel tanks.
stevef is offline   Reply With Quote
Old 10-15-2009, 08:03 AM   #14
I have a buddy that used to race carts.The engines your talking about are oollldscool.I think modern 4stroke would be 20% to 30% better on fuel econ.
Old 10-15-2009, 08:07 AM   #15
There is three advantages 2stroke have over 4stroke.Cost wight peak power output for given wight.Thats it.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
"Thump-8" 4 stroke 1/8th scale engine DP-buggyboy Onroad Nitro Engine Zone 91 07-14-2011 01:17 PM
difference between 4 cycle and 2 cycle engine? dragoneuh Onroad Nitro Engine Zone 35 01-05-2006 09:00 AM
