Old 10-13-2009, 11:27 PM   #1
Registered User
Default Standard or turbo plug?
I'm not really sure of the difference between a standard and a turbo plug engine. Would anyone be kind enough to fill me in on the differences, pros/cons, or preferences? Thanks.
rememberthis is offline   Reply With Quote
Old 10-13-2009, 11:39 PM   #2
Beddo's Avatar
A turbo plug has a tapered base which seals into the head, removing the need for the copper washer.
Turbo plugs are said to work 10-15% better than standard plugs.
Taken from the [OS engines site......
Guideline 1: Know what type of engine you have. Is it a standard - or a turbo?
Standard engines (engines with a 1-piece head) are most common. Standard plugs are easily available, inexpensive and fit almost all standard engines. Standard plugs are installed with a washer, which creates a compression seal with the head.
Many new O.S. engines are turbo engines, which feature a special 2-piece turbo head. The biggest benefit of turbo plugs is superior performance. Unlike standard plugs, turbo plugs (identified by a "P" in the description) feature a tapered "seat" that matches perfectly with the head. That creates a superior compression seal and with it, maximum efficiency and power. Turbo plugs are the choice for racers who want - and need - top performance.
A word of caution: you should never install a turbo plug in a standard engine or vice versa. Doing so risks doing serious (and expensive!) damage.
Beddo is offline   Reply With Quote
Old 10-13-2009, 11:48 PM   #3
merdith6's Avatar
Default Standard is the standard...
I like standard plugs because their 5 bucks as opposed to 10. It makes life simple to just put a medium mcoy mc 8 in and forget about it. turbo plug guys hunt for the right plug too much. IMO.
merdith6 is offline   Reply With Quote
Old 10-13-2009, 11:55 PM   #4
Registered User
Great info, thanks Beddo and Merdith.
Old 10-14-2009, 04:53 AM   #5
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
The o'donnel plug is great to use as a turbo plug. They are $5.50. I always use the 1/10th scale one in OS motors they work great.
awdcameolsx is offline   Reply With Quote
Old 10-14-2009, 07:27 AM   #6
Zerodefect's Avatar
The Odonnel 77T?
The OS turbo plugs are great but are for OS&Ninja engines. P3 has to be one of the best plugs out there for shorter tracks and P4 for larger.
Zerodefect is offline   Reply With Quote
Old 10-14-2009, 07:35 AM   #7
Originally Posted by Zerodefect View Post
The Odonnel 77T?
Yes I just checked it the 77t. They lasted me as long as the p3's I used before that. Both my v-spec and speed ran a little better with the O'donnell plug. Can't say that it will be better for all engines but that is what I like to use. And the price just went down by a buck so $4.50 is at standard plug prices. I can't say anything about the p4 plug however I have never used it.
Old 10-14-2009, 07:42 AM   #8
Turbo plugs generally last longer than standards as long as its tuned right
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Standard vs. Turbo plug jmpn02 Nitro Off-Road 6 08-31-2009 09:26 AM
Standard plug vs. Turbo plug CanyonCarverR1 Nitro Off-Road 6 10-29-2008 10:34 AM
Standard or Turbo ? wiggindude Nitro Off-Road 9 08-04-2008 04:16 AM
Novarossi Plus 21-5K or Turbo josh_c Nitro Off-Road 20 07-12-2008 08:45 PM
How to select the correct Turbo Plug? Please help :) gonzoY5 Onroad Nitro Engine Zone 9 07-18-2004 02:41 AM
